https://ausmini.com/forums/
New Era Headlight Relay
https://ausmini.com/forums/viewtopic.php?f=5&t=23960
Author:  Anto [ Mon Oct 23, 2006 2:09 pm ]
Post subject:  New Era Headlight Relay
Is this the headlight relay I want?
I found it in a box of bits from a clubby I wrecked about 5 years ago, didn't notice it till now! It has two 30 amp fuses (1 blown), two L terminals, two S terminals and a B terminal. Can anybody tell me how to hook it up. I'm hoping it still works. :wink:
Author:  Lillee [ Mon Oct 23, 2006 2:54 pm ]
Looks right but mine is MUCH newer than that :shock: :wink:
Author:  Morris 1100 [ Mon Oct 23, 2006 7:05 pm ]
That is the old style one but it should still be fine.
Very simple to hook up. It is a double switch so you can hook it up for high and low or for Left and Right high beam.
B= Battery. Run a thick cable from the battery to the B terminal.
S= Switch.
L= Light
Author:  9YaTaH [ Mon Oct 23, 2006 7:23 pm ]
Post subject:  H4 Conversion
S= Switch.
L= Light
I want to do something like this (eventually)....where do most people pick up power for there relay-ed headlights :?:
The original wiring is pathetic...so I was thinking.....use it as a switch for the relays only and maybe run a decent power cable from the starter solenoid terminal block.
Author:  Morris 1100 [ Mon Oct 23, 2006 7:47 pm ]
Post subject:  Re: H4 Conversion
S= Switch.
L= Light
Yep, run a thick wire fron the soleniod to the relay, use the original wire from the switch to the relay, run a decent wire from the relay to the lights.
Author:  Anto [ Mon Oct 23, 2006 7:58 pm ]
Well I'll be installing it at the same time as I convert to an alternator, so I'll take the regulator out, and probably join the three thick brown wires on to the B terminal - from memory one of them goes to the solenoid, one is the ignition and the other is headlight power anyway, so that should work fine.
Author:  drmini in aust [ Mon Oct 23, 2006 8:20 pm ]
Looking at schematic on box:
L1 and L2 go to lights
S1 and S2 go to high/low beam switch
B is 12V+, goes to battery cable on solenoid (use thick wire).
S is earth to a point on body- again, use thick wire.
re the L1/S1 and L2/S2, I just cut the blue/white and blue/red wires near the fusebox, and mounted the relay there.
