9YaTaH wrote:
That is the old style one but it should still be fine.
Very simple to hook up. It is a double switch so you can hook it up for high and low or for Left and Right high beam.
B= Battery. Run a thick cable from the battery to the B terminal.
S= Switch.
L= Light
I want to do something like this (eventually)....where do most people pick up power for there relay-ed headlights
The original wiring is pathetic...so I was thinking.....use it as a switch for the relays only and maybe run a decent power cable from the starter solenoid terminal block.
Yep, run a thick wire fron the soleniod to the relay, use the original wire from the switch to the relay, run a decent wire from the relay to the lights.
