It is currently Sat Jul 05, 2025 8:00 pm
 Post subject: speco wiring diagram
PostPosted: Fri Oct 06, 2006 7:42 pm
hey
in the process of building a dash i bought my tacho(2 and 3/4 / so its not huge) and i took it out of the box to measure a hole to cut, now dumb a$$ me has lost the wiring instructions,
anychance someone has this diagram lying around,
PostPosted: Fri Oct 06, 2006 10:13 pm
resident alien
resident alien
This is the rear of my speco tacho
PostPosted: Mon Oct 09, 2006 4:16 pm
If it is the 2 5/8" Pro series gauge then use these instructions:
"Matthew,
Green wire connects to “S” terminal and to negative side of coil. If there is an aftermarket tacho pick up wire, connect to this wire instead of negative side of coil.
Black wire to “G” terminal and to earth.
Red wire to “I” terminal and to ignition switch.
White wire connects to the thick black wire from lighting globe assembly and then to dash lights.
Regards,
Bob Forrest
Speco Thomas"
Matt
PostPosted: Tue Oct 10, 2006 7:10 pm
sorry guys completly forgot all about this thread,
theres a group of them red, green, white, black,
theres a big black one at the top and another small white one,
stupid enough of me to get the thing out of the box
PostPosted: Tue Oct 10, 2006 9:27 pm
resident alien
resident alien
a pic might help
