speco wiring diagram https://ausmini.com/forums/viewtopic.php?f=5&t=23340 |
Author: | buztoy [ Fri Oct 06, 2006 7:42 pm ] |
Post subject: | speco wiring diagram |
hey in the process of building a dash i bought my tacho(2 and 3/4 / so its not huge) and i took it out of the box to measure a hole to cut, now dumb a$$ me has lost the wiring instructions, anychance someone has this diagram lying around, |
Author: | Marvin [ Fri Oct 06, 2006 10:13 pm ] |
This is the rear of my speco tacho ![]() |
Author: | Matt68 [ Mon Oct 09, 2006 4:16 pm ] |
If it is the 2 5/8" Pro series gauge then use these instructions: "Matthew, Green wire connects to “S” terminal and to negative side of coil. If there is an aftermarket tacho pick up wire, connect to this wire instead of negative side of coil. Black wire to “G” terminal and to earth. Red wire to “I” terminal and to ignition switch. White wire connects to the thick black wire from lighting globe assembly and then to dash lights. Regards, Bob Forrest Speco Thomas" Cheers Matt |
Author: | buztoy [ Tue Oct 10, 2006 7:10 pm ] |
sorry guys completly forgot all about this thread, theres a group of them red, green, white, black, theres a big black one at the top and another small white one, stupid enough of me to get the thing out of the box |
Author: | Marvin [ Tue Oct 10, 2006 9:27 pm ] |
a pic might help |
