head swap? https://ausmini.com/forums/viewtopic.php?f=5&t=22861 |
Author: | russdog1 [ Sun Sep 24, 2006 11:00 am ] |
Post subject: | head swap? |
Hi, new to minis, if bore spacings are the same can a 1100k round nose head fit on the later 998 blocks? |
Author: | drmini in aust [ Sun Sep 24, 2006 11:22 am ] |
Yes, no problem. Bore size and spacing is the same, so is the block. As the combustion chamber is a little bigger on the K head, I'd deck it 1mm or so or the C/R will be too low. ![]() |
Author: | russdog1 [ Sun Sep 24, 2006 11:34 am ] |
Thanks drmini for promt reply- Russdog |
Author: | 9YaTaH [ Sun Sep 24, 2006 12:06 pm ] |
Post subject: | Re: head swap? |
russdog1 wrote: Hi, new to minis, if bore spacings are the same can a 1100k round nose head fit on the later 998 blocks?
russ...got the number off the head ![]() It may be better to check what head you have, and check with the Doc before you plonk it on to your 998cc...Cheers, Mick |
