air filters for dellortos? https://ausmini.com/forums/viewtopic.php?f=5&t=22655 |
Page 1 of 2 |
Author: | Pin4e [ Sun Sep 17, 2006 9:01 pm ] |
Post subject: | air filters for dellortos? |
i need a filter to go on the end i'm sucking dirt in the ram pipes and socks don't let any air in. Brand and where to buy/ thanks guys |
Author: | CPOCSM [ Sun Sep 17, 2006 9:09 pm ] |
The Ramflo filter will fit on the Dellorto but you may have to remove the mat on the firewall(if it aint already gone...) I got mine from Autopro or Repco may have them. Hooroo |
Author: | drmini in aust [ Sun Sep 17, 2006 11:23 pm ] |
Ramflo RF455 P5S is the one, the filter body is offset upwards. Keep an eye on the foam, when it's had it I'd buy a Unifilter LNX400 pad for $8.90. And oil it with Unifilter oil. ![]() |
Author: | Pin4e [ Thu Sep 21, 2006 9:34 pm ] |
thanks guys where do i buy one such item? |
Author: | drmini in aust [ Thu Sep 21, 2006 9:57 pm ] |
Ramflo filters here- http://www.lynxcorp.com.au/shopping/def ... &group=ALL Note the RF445 `P5S' offset bases are hard to get, you may have to order one. Unifilter foam pads here- http://www.uniflow.com.au/ p/no is LNX400. |
Author: | Pin4e [ Fri Sep 22, 2006 7:41 am ] |
thanks doc, i emailed them earlier as they were the only place i could find similiar products but they didn't write back, so i asked but its seems i may have to hassle them. thanks again. |
Author: | leyland brother [ Fri Sep 22, 2006 8:39 am ] |
Will the LNX400 also suit a weber dcoe45? |
Author: | Spaceboy [ Fri Sep 22, 2006 3:31 pm ] |
this thread should be called "air filters for dellortos?" or something like that, sorry to be a pain. |
Author: | drmini in aust [ Fri Sep 22, 2006 7:06 pm ] |
leyland brother wrote: Will the LNX400 also suit a weber dcoe45?
YES. Weber DCOE and Dellorto DHLA carbs share common inlet and outlet flange sizes. But internally, nothing is the same.... ie Weber parts only fit Weber. |
Author: | Spaceboy [ Fri Sep 22, 2006 7:24 pm ] |
i said i am sorry to be a pain about it. but it helps for people to use the search function, theres too many vague topic descriptions |
Author: | simon k [ Fri Sep 22, 2006 9:12 pm ] |
Spaceboy wrote: this thread should be called "air filters for dellortos?" or something like that,
sorry to be a pain. if you're sorry, why did you post it ![]() hahahaha you're just an easy target Ryan ![]() do you actually need sock filters for your dellorto - are you sure the ramflo isn't one that sits flush against the mouth of the carb??? like these? ![]() |
Author: | miniobsessed [ Sat Sep 23, 2006 4:51 pm ] |
Personally I'm not a fan of ramflo foam filters. It's K&N all the way.. I'm not gonna risk my 15 grand engine to a marginal filter... |
Author: | willy [ Sat Sep 23, 2006 7:57 pm ] |
miniobsessed wrote: Personally I'm not a fan of ramflo foam filters. It's K&N all the way.. I'm not gonna risk my 15 grand engine to a marginal filter...
![]() Filters only stop rocks from going in, you know this; right?...... |
Author: | Spaceboy [ Sat Sep 23, 2006 8:21 pm ] |
willy wrote: miniobsessed wrote: Personally I'm not a fan of ramflo foam filters. It's K&N all the way.. I'm not gonna risk my 15 grand engine to a marginal filter... ![]() Filters only stop rocks from going in, you know this; right?...... ramflo's only filter rocks im more concerned with dust, cos i can see how much the paper filters collect |
Author: | drmini in aust [ Sat Sep 23, 2006 8:26 pm ] |
GOOD foam filters better than paper. Ask Unifilter. ![]() I agree with comments above re Lynx's Ramflo foam, but the Unifilter (or the old Finer Filter) foam is GOOD. |
