https://ausmini.com/forums/
HIF44 Moke Manifold
https://ausmini.com/forums/viewtopic.php?f=5&t=22613
Author:  fwom moke [ Sat Sep 16, 2006 5:55 pm ]
Post subject:  HIF44 Moke Manifold
Any recommendations for a manifold to suit 1 3/4 SU and will fit a moke
Author:  gafmo [ Sat Sep 16, 2006 6:26 pm ]
Can't recomend one for you...but check out Fleebay in the UK :wink:
Maybe ask for measurments as a question
Author:  Mokesta [ Sat Sep 16, 2006 7:42 pm ]
Stock metro iron one or MG metro alloy one will work but you'll need really good engine steadys. If you can get a 1/2 thickness bakelite spacer and fit shorter studs to the manifold, then the HIF float bowl probably won't hit the firewall.
Anything longer than the above will be too long.
M.
Author:  fwom moke [ Sat Sep 16, 2006 10:40 pm ]
Anybody know whether a Minisport Light Weight Alloy (high flowing) Manfiold will fit a moke with 1 3/4 SU
Author:  Mike [ Mon Sep 18, 2006 5:52 am ]
How about the Graham Russel manifold with a steeper angle milled into the base (so it points higher and misses the firewall). Its supposed to outflow everything else bar the maniflow units.
Author:  drmini in aust [ Mon Sep 18, 2006 7:48 am ]
Mike, I'm afraid the GR is way too long, for a Moke- they have a lot less room there..
Author:  Mike [ Wed Sep 20, 2006 1:11 pm ]
ahh? ok.
