Fuel injected, turbo, 998 finally done. https://ausmini.com/forums/viewtopic.php?f=5&t=22090 |
Author: | sean0719 [ Fri Sep 01, 2006 5:24 am ] |
Post subject: | Fuel injected, turbo, 998 finally done. |
After a few weeks of hard work my mini is finally done. Short list: Haltech E6x KKK K03 turbo 300Z intercooler GM coils off an 98 Comaro with a LS1 Custom intake Custom Header Custom everything else. I'm sure I went through about 5 powerband blades and a whole box of welding rod. For a point there I thought that the welding would never end. Since cash flow was low I had to make everything from the exhaust and intake flanges to the fuel rail. The only things I didnt make is the Blow off vlave and the turbo. The intercooler was too big to fit in the grill (shocker) so that had to be cut down, and I moved the radiator to the fender and put an electric fan in the wheel well to give me more clearence for the IC piping. It was a ton of work, but hopefully I can get the little motor in the 120hp range. Hopefully I'll have some power graphs in a few weeks. The car remains un-molested, except that I had to make the hole in the right inner fender slightly larger. Cheers, -Sean http://www.imagestation.com/5718988/3979821307 ![]() ![]() ![]() ![]() ![]() |
Author: | sports850 [ Fri Sep 01, 2006 7:19 am ] |
Now that's impressive , good luck with the power figures , waiting to see what you've achieved must be frustrating .... |
Author: | 1360 LS [ Fri Sep 01, 2006 7:23 am ] |
Looks great bet she sounds fantastic.. cant wait to see the power graph. |
Author: | gafmo [ Fri Sep 01, 2006 8:05 am ] |
Author: | Mokesta [ Fri Sep 01, 2006 8:22 am ] |
Looking great. Please let the rest of us EFI-interested people know how you go with mixtures between inner and outer cylinders. If you are running sequential you could be alright and I would like to know the tricks for getting the E6X set up correctly. If you are using group fire for injectors, watch out for lean out on cylinders 2 & 3. My own EFI project is shelved while I see how successfully it can be done and I want to use the same computer. M. |
Author: | GTi_Mini [ Fri Sep 01, 2006 11:22 am ] |
mate that set up is awesome. good choice on the ECU. thats what im running. hmm that exhaust would keep your tyres nice and warm. sticky lol. |
Author: | TheMiniMan [ Sat Sep 02, 2006 2:04 am ] |
well done man, hope all goes well. should be at least 120, might even jag more than expected if it`s all a soooper sweeeet match up. keep us informed |
Author: | JC [ Sat Sep 02, 2006 8:38 am ] |
Looks great. One thing I might look at developing further is getting the blow off vavle closer to the thottle body or at least somewhere inbetween the i/cooler the throttle body. |
Author: | DOZ [ Thu Nov 23, 2006 3:03 pm ] |
Hows it running Sean? Any results yet? Cheers Daniel |
