It is currently Sat Jul 05, 2025 2:27 pm
 Post subject: temp guage?
PostPosted: Tue Nov 14, 2006 4:15 pm
hi all,
im having a little trouble with a temp guage. i have converted my clubman to a round nose and im in the process of doing the dash as well but the guage that i have reads hot when the motor is warm. i have tried a couple of different guages and senders but it stays the same any ideas? is there a voltage decreaser or something.
cheers matt
i like to drive on rails
PostPosted: Tue Nov 14, 2006 4:50 pm
How's the fuel gauge as well - if reding funny then your voltage regulator behind the instument cluster is stuffed. I can provide an electronic replacement for $20 including postage - gives a rock steady 10volt that is required for the guages
David L
