It is currently Mon Jul 07, 2025 3:26 am
PostPosted: Thu Aug 17, 2006 6:10 pm
I have a 1977 Clubman 998cc pretty much stock I believe, and I wanted to know what mods I could do to perfromance to make it perform better....
I have been offered a 12g295 head for $350:
it has new valve stem seals, polished valves and already about 80thou skimmed off it.
Has been hot bathed, blasted, has double valve springs... just needs the rocker gear from my existing head.
Would that be a good option?
All help appreciated thanks Ian
Ian - My Ve SSV Ute - Looking for a Mini
PostPosted: Thu Aug 17, 2006 7:19 pm
That head will help, but the cam is what holds 998s back. I'd bung a Graham Russell RE13 one (or similar) in while the head's off. :wink:
Can be done in the car, on smallbore motors. Just need to cut one of the radiator grille slats (one end only) in the LH inner guard. Swap cam, bend the slat back down and weld it again if you want....
OK... so I've left `a few' steps out, :lol: but it's not heaps of work if the head is off it. :wink:
<edit> you would want to improve the carburation and exhaust system too, if you really want it to sing.
PostPosted: Thu Aug 17, 2006 10:07 pm
Go for the head! Bigger carby will help with that too as that may not be expensive and will, with bigger valves etc make a noticable difference...PS in David Vizard's How To Modify A Mini, it says not to remove the cam in that fashion as you can drop it into the gearbox...but i've done a cam removal in a car before so i'm not sure. hmmm?
PostPosted: Thu Aug 17, 2006 10:26 pm
ausmini mod
ausmini mod
Knowing a bit about Ian's (YoungMiniac) mechanical knowhow... he will need help with both...
Ian, as the good doc says, you can do heaps to a 998. The simplest mod is the head. If you want more you need cam, exhaust, carby and manifold... it all adds up.
Peter.
PostPosted: Thu Aug 17, 2006 10:37 pm
Pete you are beginning to sound like me! :lol: "It all adds up" :P
First thing I would do is change the exhaust from extractors backwards. I would then look at putting in a 1098 12G202 head or if I could afford one, a 12G295. Then I'd change the carb to something slightly bigger. This will all add to more vroom :D
PostPosted: Thu Aug 17, 2006 10:41 pm
He's talking about motors with the star drive oil pump, an Oz 998 doesn't have one (the 998s were all pin drive pumps here) so it can't drop in.
Hmmm... apart from the Minimatic- so don't do it with those! .... :wink:
PostPosted: Fri Aug 18, 2006 7:04 am
ausmini mod
ausmini mod
Yeah Chong... I am ;)
Boys, just so its clear, Ian is talking about my 12g295... ;)
Peter.
PostPosted: Sat Aug 19, 2006 2:49 am
You..... COULD..... hang a supercharger off the side :wink:
PostPosted: Sat Aug 19, 2006 9:53 am
What mods are need for supercharge?
PostPosted: Sat Aug 19, 2006 11:14 pm
is there any modifications needed to the block to fit a 12g295 head
Cheers Dan
PostPosted: Sun Aug 20, 2006 7:49 am
No, none at all. :wink:
PostPosted: Sun Aug 20, 2006 8:22 am
I was waiting for that one...lolol. My personal choice.
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Sun Aug 20, 2006 11:45 pm
That all depends on a couple things.....
1. what mods are currently done to the engine
2. what kinda driver you are.... (lead foot or smooth)
If the engine has high compression or a hot cam, it wont be a completely easy upgrade.
Either way, you'll need an oil cooler, get the ignition modified to suit, maybe an upgraded fuel pump...... just as a minimum.
PostPosted: Mon Aug 21, 2006 9:45 pm
Peter just told me I need a Pulsar Dizzy :P Aparently thats the best thing to do straight away.... I am going to buy one soon and do it :D
PostPosted: Tue Aug 22, 2006 11:27 am
ausmini mod
ausmini mod
Ian,
See my post in your other thread
http://www.ausmini.com/forums/viewtopic ... 134#284134
Just be careful, yeah... after you tune it then see how it goes.
Once you start modding you kinda keep modding and it can get $$$
Peter.
