Timing Cover Leak https://ausmini.com/forums/viewtopic.php?f=5&t=21145 |
Author: | fwom moke [ Sun Aug 06, 2006 4:49 pm ] |
Post subject: | Timing Cover Leak |
Hi all Is it necessary to drain the oil to fix a timing cover oil leak? Is it necessary to use a gasket or can you just use three bond? What sort of torque is reqired on the bolts? Thanks for your replies |
Author: | drmini in aust [ Sun Aug 06, 2006 5:15 pm ] |
No you don't drain the oil. Yes you should use a new gasket, and gasket cement.. The leak is 99% bound to be the front oil seal, so fit a new one. Torque? ummmmm... VERY gentle on the small (1/4" UNF) ones... ![]() |
