It is currently Sat Jul 05, 2025 7:56 pm
 Post subject: Timing Cover Leak
PostPosted: Sun Aug 06, 2006 4:49 pm
Hi all
Is it necessary to drain the oil to fix a timing cover oil leak?
Is it necessary to use a gasket or can you just use three bond?
What sort of torque is reqired on the bolts?
Thanks for your replies
PostPosted: Sun Aug 06, 2006 5:15 pm
No you don't drain the oil.
Yes you should use a new gasket, and gasket cement..
The leak is 99% bound to be the front oil seal, so fit a new one.
Torque? ummmmm... VERY gentle on the small (1/4" UNF) ones...
:lol:
