https://ausmini.com/forums/
Moke switches into Mini K
https://ausmini.com/forums/viewtopic.php?f=5&t=20924
Author:  Klubman [ Sun Jul 09, 2006 6:55 pm ]
Post subject:  Moke switches into Mini K
Anybody know if the late Moke wipe/wash and indicator/dip switch will fit a Mini K steering column with no modifications to the column?
I am sick of not being able to reach the wiper switch in Melbourne drizzle when it has to be on/off, on/off all the time.
Author:  Mokesta [ Sun Jul 09, 2006 7:38 pm ]
No. The reset button thingy that comes out of the column is in a different spot. You are better off putting in the whole column, switches, steering lock & shroud assembly. If you want all the fruit, buy a complete Rover column from Steve @ Brickworx. Non-airbag one will have same steering wheel mount splines as your K.
M
Author:  Klubman [ Sun Jul 09, 2006 8:57 pm ]
Could I not use a Moke steering column
Author:  Mokesta [ Sun Jul 09, 2006 10:42 pm ]
Yep, just check where the piece on the outside of the column is that keys into the dash bracket & stops the whole lot from turning. It may be in the wrong spot, but I doubt it. Should be fine.
