Timing A Pulsar Distributor https://ausmini.com/forums/viewtopic.php?f=5&t=20857 |
Author: | fwom moke [ Thu Jul 06, 2006 8:07 pm ] |
Post subject: | Timing A Pulsar Distributor |
I have timed the ignition as per the Docs instructions or so I think. I stand corrected on this but the procedure for setting the timing is as follows I have a new mark on my pulley wheel, 24mm measured clockwise from the original mark. I run it to 4000+ with the vac line disconnected from the dist and plugged with a screwdriver. I advance the dist until the new pulley mark lines up with the pointer corresponding to 0, using a strobe. Anyone throw more light on this? D4R85 dist, unleaded fuel |
Author: | drmini in aust [ Fri Jul 07, 2006 7:09 pm ] |
That seems correct as a starting point. You may need a bit more advance, if highly modified. I would advise sticking it on a dyno for determining final setting. My 1360 found about 3KW this way. It is currently running at 36* total advance, but it has a pretty big cam and bathtubbed chambers- most road cars would need less. ![]() |
