https://ausmini.com/forums/
Help! she no start.
https://ausmini.com/forums/viewtopic.php?f=5&t=20847
Page 1 of 2
Author:  strat [ Thu Jul 06, 2006 12:36 pm ]
Post subject:  Help! she no start.
Hi all.
problem my mini clubman wont start :evil:
i think it is the starter motor solinoid. when you turn the key it does nothing at all. and if you try to earth out the solinod it turns over. the starter motor isnt stuck on or anything.. is this a common thing and how much roughly for a new solinoid. could it be something else.
Author:  awdmoke [ Thu Jul 06, 2006 1:50 pm ]
More likely your ignition switch or wiring.
Remove the ignition wire from the ignition switch & "hot wire" it from there.
Odds on it's the switch :wink:
Author:  pristic [ Thu Jul 06, 2006 2:07 pm ]
Probably not the solenoid, but a new one from Supercheap is about $25
Do you get ignition (alt) light and oil light when you turn the key to acc or the next one?
Peter
Author:  strat [ Thu Jul 06, 2006 2:15 pm ]
yeah everything else works lights on dash and all that when you turn the key it just goes click. :?
Author:  pristic [ Thu Jul 06, 2006 2:23 pm ]
Then as awdmoke said, get under the steering column shroud and find the wire that starts it. Hotwire your car :) and see what happens. If she starts the barell is caput (can get them easy enough though ... or get it fixed ?? )
If not, let us know...
Peter
Author:  strat [ Thu Jul 06, 2006 2:25 pm ]
sweet as mate ill give it a crack :wink:
Author:  cush [ Thu Jul 06, 2006 3:18 pm ]
welcome to mini ownership, stratton.. :)
Author:  strat [ Thu Jul 06, 2006 3:42 pm ]
gota get leon to drive it to bricks.... they will sort it out.
Author:  Morris 1100 [ Thu Jul 06, 2006 8:04 pm ]
On the solenoid there are two cables and a thin wire, a cable from the battery, and a cable to the starter and then there is a small wire from the key.
Try shorting a bit of wire from the battery side of the solenoid to the key terminal. If the starter spins you know the solenoid works. :wink:
Author:  strat [ Thu Jul 06, 2006 8:44 pm ]
yeap done that and it turns over.... so i gather it my barell or something.... cheers guys!!! top work
Author:  Morris 1100 [ Thu Jul 06, 2006 8:57 pm ]
It could be the switch or it could be the wiring.
Check out the colour of the wire where it goes onto the solenoid (white with a red stripe, I think) and find that colour on the bottom of the switch. See if it gets power when you turn the key.
Author:  strat [ Thu Jul 06, 2006 9:02 pm ]
yeah that would be nice but some clown has re-loomed my car at some stage and used the same colour wire so they are just all blue.... very fu@$ing handy.... so i think i might have to take it to an auto elec or something :evil: .
Author:  Morris 1100 [ Thu Jul 06, 2006 9:15 pm ]
I think you may have just found the problem! :lol:
OK, On the bottom of the ignition switch there are a heap of blue wires. :wink: (It doesent really matter what colour they are as long as they are good)
When one blue wire is joined to the other blue wire the lights on the dash light up. Then when the other blue wire is connected the starter spins. :wink:
Author:  strat [ Fri Jul 07, 2006 10:32 pm ]
oi.... help man dis S#!T AINT WORKIN... GOT IT 2 TURN OVA BUT NO SPARK NOW..... :evil: any other hints or should i just take it 2 a shop.... changed coil and all.... damm english electrics... :evil:
Author:  harvey69 [ Sat Jul 08, 2006 9:13 am ]
take it to the shop......
