https://ausmini.com/forums/
Needle and Spring reccomendations??
https://ausmini.com/forums/viewtopic.php?f=5&t=20186
Author:  minimechanic [ Thu Jun 15, 2006 5:38 pm ]
Post subject:  Needle and Spring reccomendations??
Ok as above needle and Spring reccomendations for a 998 with extractors/ mild cam / head work using an HS6 carb ????????
Thanks
Lucas
Author:  dirty hands [ Thu Jun 15, 2006 7:35 pm ]
Post subject:  carby springs
thats a hard question the hs carbys a good needles bend so easy in them
have you tried the fixed needle type carby ?
you can only use a few needles and the seat has to be perfect in that carby
all I can think of is trial an error with every type of needle and spring you can borrow till you find the one that you like even if the needles and springs come from a different carby
