HELP WITH ALTERNATOR WIRING https://ausmini.com/forums/viewtopic.php?f=5&t=1793 |
Author: | mini 850 ace [ Sat Sep 04, 2004 8:48 pm ] |
Post subject: | HELP WITH ALTERNATOR WIRING |
Hi I have just about finished doing up my first mini it is a 1964 morris mini 850 it has twin tanks contesser mags a full rollcage it has a 140mph smiths speedo out of a exNSW cooper S police car and a new 5" VDO tacho, CD player. The motor is a 1275 that is out to a 1380 it is running a 45 webber and a set of extractors with a big stainless steel muffler it is a metallic grey of the new BA falcon I will take some pic tomorrow I need help with the wiring with the alternator I put two power wires and one wire to the light in the speedo but it's still not working it is a lucas can anyone help thanks. ![]() |
Author: | drmini in aust [ Sat Sep 04, 2004 9:07 pm ] |
The lamp wiring goes from `ign' switch to the indicator lamp then down to the `Ind' terminal on alternator. If wired correctly lamp should light with ign on. If no lamp, alternator will not charge... |
Author: | ausminis4u [ Sat Sep 04, 2004 9:13 pm ] |
ok firstly, are u using the original wiring or have you gotten another loom made up ? if its a factoty loom and a lucas atl WITH a regulator inbuilt the wire colours are as follows : solenoid wire:brown with blue trace +ive terminal : brown sensor wire :brown with yellow trace if its a early alt with EXTERNAL reg : sensor wire :brown with yellow trace constant +ive : brown with green trace , hope this helps |
Author: | drmini in aust [ Sat Sep 04, 2004 9:26 pm ] |
I assumed you had a later Alternator with built in reg, from your comments. I wouldn't bother with the early ones. Their external regs are unreliable and hard to get new. |
Author: | ausminis4u [ Sat Sep 04, 2004 9:37 pm ] |
drmini in aust wrote: I assumed you had a later Alternator with built in reg, from your comments. yeh i was just tryin to cover all bases I wouldn't bother with the early ones. Th eir external regs are unreliable and hard to get new. ![]() |
Author: | mini 850 ace [ Sun Sep 05, 2004 8:50 am ] |
Yes it is the one with the bilt in reg it is a new loom I have wired it you myself eveything works alternator I have jost posted some pic you in gallery have a look and let me know what you think. ![]() ![]() |
