It is currently Fri Jul 04, 2025 3:07 am
Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2, 3  Next
PostPosted: Mon Mar 06, 2006 12:28 am
The nut on the First Motion Shaft came loose,causing some damage.
Have had to replace Mainshaft and 1st Motion shaft,plus bearings and bulkring.
Fitting "bling" flywheel and driveplate with the re-build. :D
PostPosted: Mon Mar 06, 2006 1:20 am
8)
Looks like some of you guys are getting serious for the upcoming Kwinana drags - that's the second lightened flywheel I've seen today, and they're both getting fitted to big bore 1275 engines :)
PostPosted: Mon Mar 06, 2006 6:06 am
Those ultra light flywheels are too light for road use, IMO.
We are sending Cody's brand new one back because:
1. it has .050" lateral runout where they had welded the ring gear on
2. it is way out of balance
3. it goes so far onto the (good) crank nose that it would need machining inside to clear the C-washer on crank.
The steel road ones are a better bet, they run true, but man they are expensive as the one above.
I lightened a stock one instead, it fitted fine no problems. 8)
PostPosted: Mon Mar 06, 2006 9:26 am
Thanks Doc.
Appreciate your concerns and advise.We will check this out before fitting...
Also changing diff ratio as well-Need to get down that 1/4 Mile quicker :evil:
The LS does very little city road use-no stop/starts-so hopefully this won't be a concern :?:
PostPosted: Mon Mar 06, 2006 10:23 am
You'll find it needs more revs to get away, that's all. And it is bound to run a bit rougher down low.:wink:
PostPosted: Mon Mar 06, 2006 6:31 pm
i was going to get a steel flywheel from mini spares uk. but after waiting 8 weeks i gave up. because they still didn't have on in stock
PostPosted: Mon Mar 06, 2006 8:45 pm
What about fitting a 3.9 diff-Doc?
Still need more rev's in 1st gear :idea:
PostPosted: Mon Mar 06, 2006 8:53 pm
Unless it's a track car 3.9 is way too low.
3.647 does me...:)
PostPosted: Mon Mar 06, 2006 9:04 pm
awdmoke wrote:
8)
I got mine 8) Care of Miniman.
PostPosted: Mon Mar 06, 2006 9:22 pm
3.647 does me...:)
And 3.9 with 12inch wheels-For the 1/4 Mile??
PostPosted: Mon Mar 06, 2006 9:29 pm
Probably.
Depends what terminal speed U got, but geared higher you would have 1 less shift, maybe.
PostPosted: Mon Mar 06, 2006 9:30 pm
Mick wrote:
awdmoke wrote:
8)
Ohhh-Mick,want to have a "pre-run" down the Freeway before April :roll: :roll:
PostPosted: Mon Mar 06, 2006 10:16 pm
I'll be lucky to have my car going before April at the rate I work at :?
I'd only bust a diff anyway knowing my luck.
PostPosted: Mon Mar 06, 2006 11:53 pm
a little OT but have you seen swiftunes newest take on the fruitfly weight /could double as a steering wheel flywheel?
no time to finish me bleedin car ..
1982 Blue-White Roof.
http://aseriesmodifications.wordpress.com/
PostPosted: Tue Mar 07, 2006 5:50 am
Hope they didn't warp the flywheel when welding the ring gear on, like MiniSpares did with Cody's... :shock:
Users browsing this forum: No registered users and 26 guests
