brake/clutch master cylinder https://ausmini.com/forums/viewtopic.php?f=5&t=1698 |
Author: | dude [ Sat Aug 28, 2004 4:29 pm ] |
Post subject: | brake/clutch master cylinder |
Hello all, Wondering if anyone can tell me if the brake and clutch master cyliner are interchangable? Or is there a mod required? Thanks. |
Author: | drmini in aust [ Sat Aug 28, 2004 5:01 pm ] |
Yeah, well.... it depends.. ![]() Most Minis have a 0.700" bore brake master cylinder (except early 850, and 998 Cooper) Most Minis have a 0.750" clutch master cylinder. If using `tin tank' MCs the flanges are different orientation between clutch and brake. Brake MCs have a slow-return restrictor valve in top, clutch ones don't. If using plastic tank cylinders (Lockheed/PBR) the 0.700 brake will work as a clutch one, but you will get less clutch stroke to release the plate, clutch will tend to drag. So.... whaddya wanna do?? ![]() |
Author: | Gareth_1330 [ Sat Aug 28, 2004 5:26 pm ] |
MOST of the ones i recondition seem to be the wrong bore for the application, and do/dont have valves where they should/shouldn'tt... I have a feeling my clutch one is incorrect.... G |
Author: | dude [ Sun Aug 29, 2004 1:02 pm ] |
Hey thanks guys just doing a restoration and have these two master cylinders, they both fit on either side, wern't sure which went were. I will just have to pull them apart and measure them up. Appreciate the info thanks. Den |
Author: | drmini in aust [ Sun Aug 29, 2004 2:27 pm ] |
On the Lockheed/PBR plastic tank ones, the bore is often marked on the body. ![]() |
