Pulsar Dizzy question https://ausmini.com/forums/viewtopic.php?f=5&t=16934 |
Author: | NAV [ Tue Mar 07, 2006 2:39 pm ] |
Post subject: | Pulsar Dizzy question |
I have gotten a pulsar distributor and modified it to fit no worries. When i hook up the blue wire to -ve and the black with white trace to +ve i get no spark. But if i put both of them on the +ve side it fire no worries. Is there something wrong here? It still runs better than the lucas one did. |
Author: | awdmoke [ Tue Mar 07, 2006 2:44 pm ] |
OK coil is hooked up with power to + and - to earth then dizzy blue wire to coil -ve and dizzy black/white wire to coil +ve ![]() |
Author: | NAV [ Tue Mar 07, 2006 3:18 pm ] |
awdmoke wrote: OK coil is hooked up with power to + and - to earth
then dizzy blue wire to coil -ve and dizzy black/white wire to coil +ve ![]() ah HA! all good now thanks awdmoke |
Author: | awdmoke [ Tue Mar 07, 2006 3:21 pm ] |
Got mine around the wrong way before too ![]() It's called "learning from your mistakes" ![]() |
Author: | Smokie [ Tue Mar 07, 2006 3:34 pm ] |
Quote: "learing from your mistakes"
I just can't help but to ask this but are you just an old learer from way back awdmoke?????? |
Author: | awdmoke [ Tue Mar 07, 2006 3:37 pm ] |
![]() Just learned that Smokie is still an old smart arse! ![]() |
Author: | Smokie [ Tue Mar 07, 2006 3:42 pm ] |
You forgot to say old smart arse Mike... ![]() |
Author: | NAV [ Tue Mar 07, 2006 4:28 pm ] |
I have another problem now it starts cutting out after 1min at 100km/h if you let it idle for a while all is good again. You can putt around with no problems,it's just at 100km/h or there abouts <edit> all sorted now twas a earthing issue it was. ![]() |
Author: | clubby123 [ Wed Mar 08, 2006 8:59 am ] |
what differences does the pulsar dizzy make cause thinking of changing mine soon |
Author: | awdmoke [ Wed Mar 08, 2006 10:37 am ] |
Reliability + you get a better "fatter" spark, and never have to change a set of points again ![]() |
Author: | fuzzy-hair-man [ Wed Mar 08, 2006 10:54 am ] |
Less timing scatter more accurate, it's not Lucas(Oh you said reliability ![]() |
