It is currently Fri Jul 04, 2025 4:57 am
PostPosted: Mon Mar 06, 2006 5:20 pm
Scored a DLHA40 for $50 bout a week ago. It seems to be in good condition, I've stripped it down, everything seems fine. I'll clean it up and put a kit through it when I get one.
My question is how do I know what to put on it? Like what size air correctors, emulsions, main jets, air pump jets?? I know chokes might require a bit of trial and error, but are all these others trial and error aswell? Or is there a standard size for mini?
If it helps my engine specs are as follows:
1100cc, kent 266 cam, will have a 202 worked head..
PostPosted: Mon Mar 06, 2006 5:35 pm
try this page
www.powerpage.dk/tuning_teori_8dellorto.aspx
should sort you out.
PostPosted: Mon Mar 06, 2006 6:32 pm
You have the same/similar setup as Josh (minimad), ask him what he runs :wink:
PostPosted: Mon Mar 06, 2006 6:41 pm
The Scotsman, thanks for that link. Very useful info.
Chong, Josh has got a much better head and an RE13 cam (I think).. That'd make quite a bit of difference wouldn't it?
PostPosted: Mon Mar 06, 2006 6:42 pm
I set Josh's 40DHLA up.:)
I'd start with-
55 idle jets
7772.5 or 7772.6 emulsion tubes
180 air jets
135 or 140 main jets.
32 or 33mm chokes. :wink:
This will work to get it going, may need to vary main jet up or down a notch.
Nowhere near as finicky as SUs... 8)
PostPosted: Mon Mar 06, 2006 6:55 pm
Cool thanks doc..
This already has 55 idle jets.. Would you recommend replacing these anyway? Are they something that can ware, or should they be fine?
It also has 145 main jets. Should I give these try to start with?
The emulsion tube is 7482.3 so that looks to be way off.
I'm not sure how to tell the size of the chokes or air jets..
PostPosted: Mon Mar 06, 2006 7:28 pm
Sorry but your looking at the wrong part the emulsion tube is the bit that goes between the main jet and air corrector the bit bit your looking at is the aux venturi I think, it does get confusing when you are new to these carbs so if unsure ask
Jon
PostPosted: Mon Mar 06, 2006 7:32 pm
Emulsion tube is the bit between the main jet and the air jet above, it's about 50mm long with some holes in the side.
Both 7772.5 and 7772.6 work in Minis, I've found the others don't.
If you need to buy some, the 7772.5 are NLA new.
No the idle jets don't wear, try it with those you have.
PostPosted: Mon Mar 06, 2006 7:38 pm
There are 16 different emulsion tubes and they all start with 7772.something. 5, 6 or 7 is the ballpark tubes depending on what you have motor-wise.
Chokes are easy to get and all of mine just happened to have 32mm chokes in them. I now have 30 mm but I think the 31mm would be perfect(still have that "GUUUURRRRGGGHHH" really early in the morning).
Your jetting is nearly ok and the easiest way to get them set up is $150 on a dyno(Autotech here in Canberra do mine - Italian gurus). I have the how to tune and rebuild Weber and Dellorto book and is very handy.
All in all a good carby - people have their prefs over whether to weber or DHLA - horses for courses. DHLA has more of a tuneable range of infinite jetting as opposed to the weber that looks better and simpler - not to mention the noise difference.
Hooroo
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
PostPosted: Mon Mar 06, 2006 8:14 pm
If it came out of an Alfa (as most 40 Dellos did) the emulsion tubes will be 7772.10, these will NOT work in a Mini- they are designed for 1 choke per cylinder. :wink:
Way too many holes in 'em...
Believe me I DID try to make them work... :cry:
PostPosted: Mon Mar 06, 2006 8:21 pm
Yep feralsprint was right, I was looking at the wrong section. Will I need to change my aux venturi?
Doc you're also right, it must have been out of an Alfa, it is 7772.10, so I'll have to change that. My air corrector is 240 so that's will need to be changed also.
Only thing I need to sus out now is the choke size. Can anyone explain how to do this?
PostPosted: Mon Mar 06, 2006 8:38 pm
there are 2 marks on the chokes - the "INC" mark and then a number("32" is 32mm)opposite it on the choke rim itself.
Should be able to see it if you get a mirror and a torch if the carby is still on the car - if not on the car, just look down the guts of it towards the butterflys
Your auxilliary venturi are correct to the mini - I personally run a .1 but thats just me. The .3 will run A/OK in your mini
Hooroo
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
PostPosted: Mon Mar 06, 2006 8:39 pm
look in from air intake there is a number on top of choke tube.
<edit> if you can't read it undo the locknut and screw on bottom, slide aux venturi and choke tube out. DO NOT FORCE it the aux venturi is very fragile.
Last edited by drmini in aust on Mon Mar 06, 2006 8:51 pm, edited 1 time in total.
PostPosted: Mon Mar 06, 2006 8:40 pm
I did too Kev - went like crap and laid smoke all the way to fyshwick!!
Hooroo
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
PostPosted: Tue Mar 07, 2006 6:13 am
Well it seems to have 32mm chokes in there at the moment. So looks like I just need new emulsion tubes and air jets. I'll see how the 145 main jets go, as doc said they may need some adjustment.
At the moment I'm trying to get a service kit for it. Rang one Repco branch and the bloke had no idea what a dellorto was. Told him not to worry about it, so I rang another Repco and this guy asked what model and year car it was off, I said an Alfa around 1970. He reckons there was a kit available but wasn't 100% sure if it was a for a dellorto or not. So I rang another Repco and he wasn't much help either.. Told me he'd try and find out and ring me back tomorrow.
Does anyone know if Repco does actually stock kits for dellortos? Anywhere else I should try?
Users browsing this forum: No registered users and 28 guests
