Rod change gear shift bush https://ausmini.com/forums/viewtopic.php?f=5&t=16331 |
Page 1 of 2 |
Author: | Marvin [ Sat Feb 18, 2006 1:45 pm ] |
Post subject: | Rod change gear shift bush |
Ok so I got one of these ![]() to fix this ![]() my question is... How do I get in there to replace it? |
Author: | sports850 [ Sat Feb 18, 2006 1:54 pm ] |
If you look on the collar on the shaft behind where you've got the red circle you'll see a pin through the collar vertically . On the front end of the same collar there's a pin through horizontally (not too clear in your photo) , knock this pin (put the gear into 2nd , 4th or reverse , so the rod is all the way in) out with a punch that's similar size , not smaller as the pin's hollow . Once this is out , pull the rod change back and the rod with the collar will come away from the gearbox . Then with a small screwdriver pull the old seal out and follow Matt's instructions to fit the new one . |
Author: | Marvin [ Sat Feb 18, 2006 1:59 pm ] |
Cool thanks |
Author: | Marvin [ Sat Feb 18, 2006 2:29 pm ] |
Can't seem to find anything that is easy to get into position. The exhaust bracket is in the way too. What do you use? |
Author: | drmini in aust [ Sat Feb 18, 2006 2:38 pm ] |
Put it into Reverse then use a BFH and a 3/16" pin punch to knock the front pin out of the shaft. If exhaust is in the way, drop it off. ![]() |
Author: | Marvin [ Sat Feb 18, 2006 2:47 pm ] |
Tools are pretty limited (no garage to store them in)... will see what I can find. Thanks |
Author: | Marvin [ Sat Feb 18, 2006 3:41 pm ] |
This is f'd!!! ![]() ![]() ![]() ![]() ![]() ![]() |
Author: | Marvin [ Sat Feb 18, 2006 4:00 pm ] |
Finally got it... but whoever put that pin there should be SHOT!!!!!! ![]() ![]() ![]() ![]() ![]() |
Author: | drmini in aust [ Sat Feb 18, 2006 4:15 pm ] |
Go buy a proper set of pin punches, Chinese or Indian are OK and CHEAP! ![]() |
Author: | Marvin [ Sat Feb 18, 2006 4:45 pm ] |
Are those black circles in the first pick the proper seals? Do I really need to remove the old seal? Can I just put the silver one in and be done with it? My neck's getting sore ![]() ![]() |
Author: | Marvin [ Sat Feb 18, 2006 7:23 pm ] |
Tried for over an hour... couldn't get the seal to move. Any suggestions? |
Author: | sports850 [ Sat Feb 18, 2006 8:26 pm ] |
Since you've spent the money on a decent knew seal (O-ringed doover , we'll call it a seal) you might as well do it right and remove the old seal , best is normally a fine pin punch or similar into the mid section of the seal , not the outer edge and not the inner edge of the hole where the rod goes but into the "meat" in the middle . Once you've squashed it a bit you should be able to get a bite on it with the punch and lever it out . Once you've got it out check there isn't another one inside , the old trick used to be jam a second one in on top of the old one for a better seal , sometimes it works , sometimes it falls out again ... |
Author: | drmini in aust [ Sun Feb 19, 2006 6:13 am ] |
If all else fails there is room in there for up to 4 seals on top of each other. ![]() BL must have anticipated the leak problems! |
Author: | Marvin [ Sun Feb 19, 2006 2:23 pm ] |
How far should i be able to stick a small screwdriver in after i removed it? I stick one in but it only goes in about 3 x the thickness of the seal. BTW I bent nearly ALL of my small screwdrivers trying to get the f'r out ![]() edit: and what do you all use to knock it in with? |
Author: | sports850 [ Sun Feb 19, 2006 4:29 pm ] |
Got your PM and replied Marvin |
