It is currently Thu Jul 17, 2025 3:17 pm
PostPosted: Mon Feb 20, 2006 10:10 am
Just reading the other post re. security etc. I was very seriously considering installing door popppers for security reasons and also with my clubby you can only lock the doors from the outside far as I know so if I had a passenger I gotta shut my door, lock it go round the other side n lock that door too sounds like a real hassle - also if my keys scratched the paint over time id be real pissed. Given whether or not that they are fittable to a mini, Are they really illegal? Unsafe? any help would be much appreciated I just dont know what the right thing to do is......
Trixi.
Size DOES Matter!!!
PostPosted: Mon Feb 20, 2006 11:56 am
i would buy em, then smooth out the door holes, i recon it would bea big job, i think its illegal if you dont have a handle, incase of crashes
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Mon Feb 20, 2006 12:21 pm
Hey,
Should be able to lock your passengers door from the inside. I can with mine. Or i used to . I now have keyless entry.
b
http://www.cardomain.com/id/skimini82
PostPosted: Mon Feb 20, 2006 1:49 pm
as long as you have a manual entry point (i use a rod on the top of my door...) it is legal, i have done this t about 8 cars, then just welded plates into the handle holes...
http://www.minisport.com.au
the guys there are dead set champions
