It is currently Sat Jul 05, 2025 7:54 pm
 Post subject: Rear hub removal
PostPosted: Thu Feb 16, 2006 6:42 pm
Not sure if this is in the right area .......... but anyway i have a question
I need to put some spacers over the rear drums, I bought the right length wheel studs......now the day and a half of bitchin and swearin begins - getting the old ones out and the new ones in.
I have found out that you need to remove the hubs to do this god forsaken task.... Is there an easy way to do this? Do I need a tool/puller? Would anyone in Brisbania happen to have one of these I could please borrow, beg, steal or hire? Should I replace any bearings or seals while I have the hub off? What grease should I use when repacking? and last but not least - are there any tips or tricks I should watch out for?
Cheers Gerard
PostPosted: Thu Feb 16, 2006 7:07 pm
You need a bog breaker bar :) and the rear LH hub thread goes the opposite way..
PostPosted: Thu Feb 16, 2006 7:22 pm
Undo the hub nut, if the hub doesn't budge get/make a slide hammer/puller.
Mine is scrap metal, the impact energy is provided by a dead Morris 1100 harmonic balancer.:)
PostPosted: Thu Feb 16, 2006 7:28 pm
loosen the nut but leave on , then bolt wheel on and give it a kick or 10, if that fails slide hammer on a wheel stud. or bring it to my shop at morningside and i will tap it off 4 ya
PostPosted: Thu Feb 16, 2006 9:22 pm
thanks so much guys ...... will give it another go on saturday
What shop u got dodge???
Cheers Gerard
