It is currently Sat Jul 05, 2025 2:42 am
PostPosted: Thu Feb 16, 2006 11:12 am
It's commented on frequently that a good 'upgrade' is to fit wet front upper arms to a dry car for a firmer ride. Anyone actually done this? Is the difference noticable? Is it a good thing? Or just a thing....
PostPosted: Thu Feb 16, 2006 1:06 pm
I've got Hydro top arms on my dry Deluxe ...
definitely harsher.... I've deliberately fitted HARD sagged cones to mine too .... it corners like a brick.
Definitely not a "comfort" mod, but certainly the same as uprating the springs a step or two ....
J
PostPosted: Thu Feb 16, 2006 7:20 pm
Wife's car (Barney) has a wet front subframe converted to dry, with good cones. Ride is a little firmer than a dry one (it has Konis) but not harsh.
PostPosted: Fri Feb 17, 2006 4:48 am
Is the difference something that's going to be measurable with them in situ? Or are we talking 1/16" or something. Just wondering if the pair in a race shell I have are wet or dry.
PostPosted: Fri Feb 17, 2006 6:25 am
it's only couple of mm I think, hard to see.
If unmolested, the hydro ones have a ~9.0mm mounting hole in top arm, where dry ones are 3/8". :wink:
But if already drilled out, hard to pick difference.
PostPosted: Fri Feb 17, 2006 6:37 am
These arms are already in a dry car, so would have been drilled if they're wet.
Doesn't matter, I'll leave be and sell the wet arms. Thanks
Users browsing this forum: No registered users and 36 guests
