It is currently Fri Jul 04, 2025 7:40 am
 Post subject: subframes
PostPosted: Tue Feb 14, 2006 2:22 pm
Die Die Die!!
are there any differences between say a 1974 leyland clubman subframe, and a morris round nose subframe ?
PostPosted: Tue Feb 14, 2006 2:27 pm
Unsure about Clubman to Morris, but there is a difference between hydro and dry.
Pete
PostPosted: Tue Feb 14, 2006 2:58 pm
No, there are three types..dry..wet and matic..which were also wet, just a little more room for the autobox'..
PostPosted: Tue Feb 14, 2006 4:01 pm
Die Die Die!!
so they should be interchangeable ?
PostPosted: Tue Feb 14, 2006 4:06 pm
yeap
PostPosted: Tue Feb 14, 2006 4:13 pm
be careful, they may bolt up the same butthey arent 100% interchangible. the pot jointed minis (clubmans and english minis from 1970 on)
have a larger hole in the subframe where the pot joints fit through. if you are fitting clubman frames to a roundie, no probs. but be cautious if you are goin the otherway.
lookin for another clubby
PostPosted: Tue Feb 14, 2006 4:16 pm
Die Die Die!!
ahh awsome cheers for the help people, and yeah clubbies onto a roundie :)
PostPosted: Tue Feb 14, 2006 4:32 pm
no probs then :D
