It is currently Sat Jul 05, 2025 11:46 am
PostPosted: Mon Feb 20, 2006 7:13 am
Hello, Im guna get a mini in a few months time.. And the one im thinking of getting needs a new paint job. And im wondering how much would that set me back? :D Thanks
PostPosted: Mon Feb 20, 2006 7:47 am
Whats the saying? If you have to ask you can't afford it? :D
If it's the pros doing it you might get out of it for 2-3k, but price goes up if it needs panel repairs.
PostPosted: Mon Feb 20, 2006 11:13 am
Die Die Die!!
for interior + boot + outside + engine bay in gloss black i got got a quote of $10,000
PostPosted: Mon Feb 20, 2006 11:54 am
it all dependds on what you want dione. if you need panel work done, the price will skyrocket, it also depends on what type of paint you want to use, 2pak or acrylic, be friendly with apainter and you could probably get away with it for around 1500- 2000
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Mon Feb 20, 2006 1:01 pm
yep! that's my experience too...if you want AWESOME paint inside and out yer looking at around the $10,000 mark (depending on the amount of prep work that needs doing)...if yer car's a crap-sandwich and need alot of attention to the body $10,000 would be cheap...
if yer just doing the exterior (ie. not painting the engine bay or the interior) and are satisfied with the color it came in then you can get away with a couple of grand ($3000 give or take) but if you want it done inside and out and for it to be pretty much perfect yer getting into some serious money...as i've found out :) got a quote for between $14,000 and $25,000 for mine from a place up here...and i've been told its in pretty good nick...just talk to morphias about how much his set him back :)
Bling me up Scotty!
