Su Carbs https://ausmini.com/forums/viewtopic.php?f=5&t=15984 |
Author: | cush [ Wed Feb 08, 2006 9:50 am ] |
Post subject: | Su Carbs |
I have a feeling i may need to fix my carb... (it's only leaking fuel) so i figured i might go to a hif 1.5 inch considering how f250 drivers think i drive. ![]() but.. Which carb is which? I always get confused when the Hif44,hs6, etc is used to describe carbs... can someone list the "other names" for the different sized carbs as per the float bowl position ( i'm not fussed about the left/right handed ones but it may be a useful reference) can someone fill in the blanks... 1.25" = hs(whatever) 1.5" = hs(whatever) 1.5" (hif) = HIF(whatever) 1.75" = hs(whatever) 1.75" (hif) = HIF(whatever) 2.0" = hs(whatever) |
Author: | EST-071 [ Wed Feb 08, 2006 10:28 am ] |
Post subject: | Re: Su Carbs |
cush wrote: can someone fill in the blanks...
1.25" = hs2 1.5" = hs4 1.5" (hif) = HIF38 1.75" = hs6 1.75" (hif) = HIF44 2.0" = hs8 Pete |
Author: | Angusdog [ Wed Feb 08, 2006 10:40 am ] |
1 plus the number of eighths of an inch. So HS2 = 1 inch plus two eighths of an inch, HS4 = 1 inch plus four eighths of an inch. HIF38 = 38 milllimetres. i.e. what he ^^^ said, but in an easy to remember format. I believe... |
Author: | cush [ Wed Feb 08, 2006 10:51 am ] |
Ah.. perfect.. thanks.. |
Author: | kazjim [ Wed Feb 08, 2006 1:11 pm ] |
also 1.75" (hif) = HIF6 (Turbo Version) |
Author: | cush [ Wed Feb 08, 2006 1:13 pm ] |
oh ya.. the pressurised bowl business.. ![]() |
Author: | drmini in aust [ Wed Feb 08, 2006 7:59 pm ] |
There was an HS7 too, I heard- 1-7/8"... ![]() |
Author: | TheMiniMan [ Wed Feb 08, 2006 11:45 pm ] |
yeah i`ve heard that plenty of times but don`t believe i`ve actually ever seen one in the flesh then there is all the earlier versions,,,just plain "H" series still with side float bowl but a big alloy bolt fits it to the body of the carb from underneath & they also had a funny little "gland seal" that was common leaker with old age & also the carb bodys were a bit longer. just a bit of trivia for you all ![]() |
Author: | drmini in aust [ Thu Feb 09, 2006 5:54 am ] |
TheMiniMan wrote: yeah i`ve heard that plenty of times but don`t believe i`ve actually ever seen one in the flesh
then there is all the earlier versions,,,just plain "H" series still with side float bowl but a big alloy bolt fits it to the body of the carb from underneath & they also had a funny little "gland seal" that was common leaker with old age & also the carb bodys were a bit longer. just a bit of trivia for you all ![]() Works cars in UK used to run H4s, as they bolted straight onto the early Cooper & S manifolds. Their bolt pattern was same as an HS2. ![]() ps they missed one on that list- 2x HS1s were used on 948 Sprite I think. 1-1/8". |
Author: | sports850 [ Thu Feb 09, 2006 7:05 am ] |
drmini in aust wrote: ps they missed one on that list- 2x HS1s were used on 948 Sprite I think. 1-1/8".
Yeah , I've got a manifold for twin 1 1/8's that cost a 6 pack from someone who'd bought it for a mini and found they couldn't use it for twin 1 1/4" SU's , I was always going to find a couple of 1 1/8's and use it on an 850 for some fun (something different) but then found the sports850 and didn't bother . The studs look the same as in 1 1/4" (vertically opposed) but are way too close together for the 1 1/4" to fit , it's now on "the wall" in the shed as an oddity . |
Author: | Keith Calver [ Mon Feb 13, 2006 5:14 am ] |
HIF7s were fitted to the straight-6 Jags prior to injection. Excellent carb if you know what to do with it on a Mini (ask GR). Two issues with HIF carbs - the bi-metal strip controlling the jet height, and the float bowl capacity... KC. |
Author: | Christoph [ Thu Feb 16, 2006 3:59 pm ] |
Didnt the XK engines also use HD8's? |
