2" SU https://ausmini.com/forums/viewtopic.php?f=5&t=15930 |
Author: | Besser [ Mon Feb 06, 2006 3:31 pm ] |
Post subject: | 2" SU |
On a Hot 1275+ why wouldnt you run a 2"SU? |
Author: | fuzzy-hair-man [ Mon Feb 06, 2006 4:43 pm ] |
In most cases I think the 2 inch would be too big 1" 3/4 seems to do fine if you want bigger most people go a 45 webber or dellorto The bigger carb you got the more you lose torque down low ![]() |
Author: | Besser [ Mon Feb 06, 2006 10:13 pm ] |
Post subject: | really |
I would have thought I would lose response due to inertia of the larger parts but Torque? wow why is that? |
Author: | h0nk [ Mon Feb 06, 2006 10:43 pm ] |
I'd agree with the torque.. I drove a clubby with an 1100cc engine today.. it had twin 1.5" SUs on it.. it was powerful, but didn't have much torque down low.. My deluxe has twin 1.25" and you can really notice the difference. On corners I could take in 3rd in my car, it would shudder and I'd have to switch down to 2nd in the clubby.. just an example.. |
Author: | drmini in aust [ Tue Feb 07, 2006 5:49 am ] |
Twin HS4s are really too big on an 1100, unless it's a race motor. Twin HS2s suit them great. ![]() |
Author: | dodge [ Tue Feb 07, 2006 9:23 am ] |
i used a jag 2"on my blown engine, it worked well, had to upgrade the feul line to 10mm tho |
Author: | TK [ Wed Feb 08, 2006 8:13 pm ] |
here we go again, With the SU the piston rises to allow what the engine requires in Air and fuel. The SU is a fab carb because of this. "On a Hot 1275+ why wouldnt you run a 2"SU?" I ran twin 1.75 inch SUs on a street 1330 no worries. Also I ran a 1275 eater 998 screamer with a 1.75 inch SU again no worries. The SU is different from like a Weber that forces fuel into an engine with a pump of the pedel. Mad Matt back me up. |
Author: | TheMiniMan [ Wed Feb 08, 2006 8:21 pm ] |
![]() There you have it... a 2 inch SU on a big bore (just happens to be 1510cc big bore tho) & i`m building the """twin"""" 2 inch SU set up for it now ![]() HELL YEAHHH!!!!!!!!!!!!!!!!!!!!!!!!!!!! |
Author: | cush [ Wed Feb 08, 2006 9:26 pm ] |
i knew mat would pipe up ![]() |
Author: | TheMiniMan [ Wed Feb 08, 2006 10:44 pm ] |
hee hee,,,you`re getting to know me well hey cush ??? & i once set up a pair of twin 1&1/4 SUs on a honda zot,,,you know , the little 360cc bike engined things??? well they`re not quite a 2" but it`s the same comparison really on such a small donk,,,& yeah i did have to light weight the carby pistons to get it to respond better & also had a huge time with modifying the dampeners, but then,,,,,well,,,,even i was impressed, you should have seen the look on the face of the customer after he took it for a spin ![]() as Ty says,,,they`re a pretty dam versatile carb, & it`s the simplicity of the variable ventury that allows them to be suited so well to anything, big or small, just that you really do have to "Know" what to do when doin something "out of the ordinary" , you can`t just expect to bolt it on & be sweet. |
Author: | gafmo [ Thu Feb 09, 2006 6:24 pm ] |
I agree I love my 1 3/4 on a 1100 |
Author: | simon k [ Thu Feb 09, 2006 9:07 pm ] |
spaceboy's mate in SA won (but 'officially' lost on a technicality) hays heroes in a shitter 998 with a 2" SU on it a few years ago |
