https://ausmini.com/forums/
Hose too long?
https://ausmini.com/forums/viewtopic.php?f=5&t=15850
Page 1 of 2
Author:  Marvin [ Sat Feb 04, 2006 4:40 pm ]
Post subject:  Hose too long?
This heater hose it getting annoying. I know it shouldn't be that long.
Does anyone have a pic of how it should actually look?
Also, is the Hot/Warm/Cold control in the right spot? Should it be screwed/bolted to something?
Author:  Morris 1100 [ Sat Feb 04, 2006 7:54 pm ]
Yes that heater tap is in the wrong place... The correct location for that heater tap is under the bonnet of a HZ holden. 8)
The Clubbie heater tap is a POS and they have replaced it with a Holden one. You may be able to mount it better (I doubt if you could mount it worse!) You may be able to mount it the other way up.
Author:  Marvin [ Sat Feb 04, 2006 8:03 pm ]
Image bloody typical... will see what I can do.
Author:  Mini Mad [ Sat Feb 04, 2006 8:09 pm ]
Bloody Martians :roll: :lol:
Author:  Marvin [ Sat Feb 04, 2006 8:12 pm ]
Hmmm... I think I may have bought the car off a Saturnian :lol:
Author:  drmini in aust [ Sat Feb 04, 2006 8:46 pm ]
Put it up on the back of motor where you can get at it..
Or do what we did, leave (clubby one) off. 8)
Author:  Marvin [ Sat Feb 04, 2006 8:59 pm ]
So you've got it set at hot all the time?
Author:  drmini in aust [ Sat Feb 04, 2006 9:00 pm ]
Yeah but just turn air off in summer, use the 1/4 windows. That's what they're for... :wink:
As said, Clubby tap is a right POS...
Author:  Morris 1100 [ Sat Feb 04, 2006 9:06 pm ]
The Australian Morris 1100 heater does not have a tap. They use the heater for extra engine cooling. When you want hot air you open the flap to let the hot air in the car.
Author:  Mini Mad [ Sat Feb 04, 2006 9:08 pm ]
Sounds like a 'matic heater too..
Author:  drmini in aust [ Sat Feb 04, 2006 9:15 pm ]
No it's not, if I remember it's in car like a Clubby...??
Clubby has air flap, just leave off unless you want heat. :wink:
Hey it's not like it's a UK one with those new-fangled fresh air vents..
Cooper S handbook used to say turn heater on if engine gets too hot..
Author:  Morris 1100 [ Sat Feb 04, 2006 9:25 pm ]
Yeah, It is in the car under the dash. The air feeds in from the plenum through the top.
Author:  gafmo [ Sat Feb 04, 2006 9:30 pm ]
the tap does bugger all anyway..just stuffs the cooling system..let the water run through and all will be sweet and the hose will be nice and short also 8)
Author:  Marvin [ Sun Feb 05, 2006 6:27 pm ]
Let's just say that the heater's a whole lot freakin easier to get in than out!!! Well it was once all the extra hoses were gone.
Author:  Morris 1100 [ Sun Feb 05, 2006 6:38 pm ]
That looks much better. :D
Did you keep the tap or remove it?
