It is currently Fri Jul 11, 2025 1:37 am
PostPosted: Fri Feb 03, 2006 10:10 pm
I want to replace the struts with Hilos. How do I remove the cone from the strut. I have tried and tried and the only option I can see now is to use the grinder to cut the strut away from the cone.
Any idea or suggestions would be great
Don't argue with an idiot; people watching may not be able to tell the difference !
PostPosted: Fri Feb 03, 2006 10:24 pm
Not sure myself but you might get a better response if you post this under Mini chat or Mini mods. This area is for pics. :roll:
2008 Prado GXL
PostPosted: Fri Feb 03, 2006 10:26 pm
http://www.ausmini.com/forums/viewtopic.php?t=15587&highlight=top+rod
PostPosted: Sat Feb 04, 2006 12:05 pm
I used a chisel and BFH on one.. but i couldn't get the other apart, some of them are stuck together REAL GOOD.
I replaced my cones with new ones when i did my hi-lo's...
