https://ausmini.com/forums/
Cannibals at the Wreckers or What Other Makes' Bits Fit.
https://ausmini.com/forums/viewtopic.php?f=5&t=15764
Page 1 of 2
Author:  Hagar [ Wed Feb 01, 2006 9:24 pm ]
Post subject:  Cannibals at the Wreckers or What Other Makes' Bits Fit.
ok...
...I've got my Nissan distributor and my Sigma (Bosch) alternator, what other makes' bits are useable? I see references to Holden bits and possible Pulsar alternators in the Pulsar dizzy thread. - more info pls!
Apart from the obvious BL/BMC/MOWOG bits - duh! :lol:
I'm always on the lookout for parts and spares etc, and the Toowoomba swap meet is this weekend...
...two days of car parts and heatstroke - woohoo!
Author:  awdmoke [ Wed Feb 01, 2006 11:53 pm ]
Gemini starter motor
Also disc brakes can be adapted from Holden Camira & Honda City (Accord too, but more work aparently).
Gemini mags will "sorta" fit Mokes too - 100mm PCD Vs 4" PCD
Seats: Mazda MX-5, Honda, Subaru or most small jap cars can be made to fit
Oh, and get me a thermo fan with shroud :)
Author:  nathanSMC [ Fri Feb 03, 2006 9:26 am ]
n13 pulsar alternator
any good nic toyota thermo fan (cuz they are made by denso)
as said gemini starter
dunno what else...... but buy it if its cool, and make it fit
Author:  kazjim [ Fri Feb 03, 2006 9:45 am ]
Early Corolla Rockers....make nice high-ratio rockers - Ask DRMINI
HQ-HZ Holden altenators.. a little fiddly, but put out around 90 Amps...
Mazda Famila GTX - Great Turbo for Small-blocks
etc etc etc
Author:  cush [ Fri Feb 03, 2006 9:48 am ]
12' hb torana and hillman imp rims are the right pcd for the mini
Author:  Fat Boy Dave [ Fri Feb 03, 2006 11:22 am ]
Toyota Superchargers :twisted:
Author:  DarkenMini [ Sat Feb 04, 2006 12:53 am ]
Does the Little Mighty Boy have disk Brakes? ive always thought about what Would be usefull from the little mighty boy
Author:  drmini in aust [ Sat Feb 04, 2006 9:29 pm ]
Well... Twincammini on here has one with a Suzuki Cappucino twincam turbo donk, says one prob now is the brakes on the turbo towel-rail are not good enough! :lol:
But hell, it GOES..... 8)
Author:  ausminis4u [ Sun Feb 05, 2006 5:46 pm ]
they do have discs but the stud pattern is the same as a swift.
dash boards from daihatsu miras and subaru fioris can be made to fit.
honda cicic brakes can also be adapted
VW golf (mk1) centre consoles can be modded to fit.
Author:  DarkenMini [ Sun Feb 05, 2006 9:34 pm ]
wow a capachino Engine fits In a Mini what siz are those Capas anyways?
Author:  DarkenMini [ Sun Feb 05, 2006 9:37 pm ]
did i read Right DR?
Author:  drmini in aust [ Sun Feb 05, 2006 10:04 pm ]
NO. read what I said above, it's in a Mighty Boy. Now MORE Mighty... :P
Yes twincammini is the owner... 8)
Author:  britishvita [ Mon Feb 06, 2006 9:47 am ]
Cappuccino engine is a 3cyl 660cc twin cam engine.
Can be made to go VERY fast with new bigger turbo and manifold, exhaust & air filter.
I used to own one and could beat HSV R8's, although once you get over 120 they start to fly by as the engine starts to run out of puff
Author:  erin [ Sat Mar 11, 2006 4:47 pm ]
I wonder if the cappucino turbo engine makes for a viable conversion for the mini..?
Any thoughts Doc?
Author:  drmini in aust [ Sat Mar 11, 2006 7:50 pm ]
Well it would fit in I'm pretty sure, but don't expect any torque from it. You have to spin it hard to make it GO.
And a Mini is heavier than the Mighty Boy, which probably weighs only 500Kg dripping wet. :lol:
Here's a pic, courtesy of twincammini... :wink:
