It is currently Fri Jul 04, 2025 7:56 am
 Post subject: Fudged Steering rack??
PostPosted: Wed Mar 22, 2006 3:24 pm
I have about 4mm play in the rack when I pull the wheel toward my chest, there is also noticible play side to side.
What is the best option?
* Is it something simple that has gone loose and easily fixed
* Bugger it and get a new rack
I have dreaded doing this job since ive had the car is there a trick to making the job easier?
PostPosted: Wed Mar 22, 2006 3:52 pm
i hope you're not checking that while driving... :shock:
PostPosted: Wed Mar 22, 2006 4:12 pm
Check that the pinch bolt at the bottom of the column is tight and the easiest way of doing it is to get someone else to do it :lol: apart from that follow the manual its not that bad really just allow a day to do it
Jon
PostPosted: Wed Mar 22, 2006 4:55 pm
If you want to avoid a major accident....get it fixed soon as :idea:
PostPosted: Thu Mar 23, 2006 1:57 pm
If you want to avoid a major accident....get it fixed soon as Idea
Yeah we dont need another mini going to the grave.
Its not on the road atm I noticed the increased play in the rack after putting it back on the ground, its been on stands for the past 3 months.
PostPosted: Wed Mar 29, 2006 8:52 am
i picked a new rack from minisport for around 240 i think, cant really rememba, better off fixing it that crashin
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Wed Mar 29, 2006 3:37 pm
Before you do anything to serious. Theres a small bit of felt, damp with oil at the bottom of the steering column, between the column and the shroud.
When that wears out you get some movement in the steering column, sounds like what you're describing. I don't know if you get the up/down movement though.
Should be able to fix that in 30 mins for 20 cents, rather than a new rack.
 Post subject: Warning
PostPosted: Fri Mar 31, 2006 10:05 pm
jimbo wrote:
Before you do anything to serious. Theres a small bit of felt, damp with oil at the bottom of the steering column, between the column and the shroud. When that wears out you get some movement in the steering column, sounds like what you're describing. I don't know if you get the up/down movement though.
Jimbo...whilst your advice may well be right in certain cases....
IT IS IMPORTANT
that Mini owners who are not mechanically savvy
err
on the side of safety
in this
IMPORTANT AREA
thats why, some of us older hands tend to recommend replacement racks and great care in the pinch bolt area....
MINI STEERING RACKS CAN BITE :idea:
PostPosted: Fri Mar 31, 2006 10:15 pm
I agree with both Mike and Jimbo.
I would check the Felt and the possible plastic one in the top, as well as the pinch bold and also the U bolts ensuing all is tight and as should be. also check the bracket to the bottom rail on the back to column.
But if in dout get some one to have a look at it for you..Mini mech that is :wink:
Users browsing this forum: No registered users and 28 guests
