Fuel Line Legality https://ausmini.com/forums/viewtopic.php?f=5&t=15515 |
Author: | leylandohc [ Thu Jan 26, 2006 9:27 am ] |
Post subject: | Fuel Line Legality |
Hey Guys, Just a quick One, Does anyone know if its ok to run EFI Lines inside the car or do they all have to be run underneath Thanks, Ash |
Author: | leylandohc [ Thu Jan 26, 2006 9:52 am ] |
Ps, out of interest does anyone know where i can download the Second edition Australian Design Rules which relate to motor vehicle safety - I have the index of it but not tha actual rules |
Author: | Idearat [ Thu Jan 26, 2006 11:44 am ] |
hi, dunno about the RTA laws, but i know that in competition (CAMS ect) fuel lines are run inside, but they have to be solid lines.... so long as you put a shild around them, i dont think there would be any problems with it.... hope that helps in some way |
Author: | WhoDat [ Thu Jan 26, 2006 9:06 pm ] |
leylandohc wrote: Ps, out of interest does anyone know where i can download the Second edition Australian Design Rules which relate to motor vehicle safety - I have the index of it but not tha actual rules
This what you after? http://rvcs-prodweb.dot.gov.au/ADRS.html Take your pick |
Author: | awdmoke [ Thu Jan 26, 2006 10:16 pm ] |
I believe they can be run inside but need a physical barrier - plate etc. (e.g. where the moke fuel lines run inside the footwell to the firewall). Not best practice though... |
Author: | leylandohc [ Fri Jan 27, 2006 6:07 pm ] |
Yeah i dont realy want to run the lines through the car(brothers idea), but not sure if a 8m efi, and two 6mm return lines will fit in the std spot. Anyway if they do go inside there guna have to go around/over the seat xmember |
Author: | ausminis4u [ Sat Jan 28, 2006 8:29 am ] |
leylandohc wrote: Yeah i dont realy want to run the lines through the car(brothers idea), but not sure if a 8m efi, and two 6mm return lines will fit in the std spot. Anyway if they do go inside there guna have to go around/over the seat xmember just run the 8mm down one side (under the shield) and the 2 6mm under the other side ( under the other shield)
Author: | leylandohc [ Sat Jan 28, 2006 9:20 am ] |
a good idea but the battery cable still has to run somewhere (although i would rater put that indide than the fuel lines).....Im now thinking of putting a spacer between the floor and the original fuel bashplate to give a little extra room |
Author: | JC [ Sat Jan 28, 2006 10:00 am ] |
Why do you need to run two return lines? Most engine conversion people just use the factory mini line for the return line and runt he new (bigger) in parrallel |
Author: | ausminis4u [ Sat Jan 28, 2006 12:54 pm ] |
leylandohc wrote: a good idea but the battery cable still has to run somewhere (although i would rater put that indide than the fuel lines).....Im now thinking of putting a spacer between the floor and the original fuel bashplate to give a little extra room just run that inside then . problem solved.
