Quick shift https://ausmini.com/forums/viewtopic.php?f=5&t=15298 |
Author: | chasg [ Sat Jan 21, 2006 1:30 pm ] |
Post subject: | Quick shift |
Decided today to install the rod change quick shift l purchased about 6 months ago. Installation went ok except l cannot engage reverse. When trying to engage reverse the lever becomes loose like it has come out of the rod change coupling. All other gears are working fine. Any Ideas ? |
Author: | Thorlek [ Sat Jan 21, 2006 3:50 pm ] |
i remember reading something about this problem a few days ago... let me see if i can find the link,,, damnit.. cant find it.... and i have no idea what it said ![]() |
Author: | meeni [ Sat Jan 21, 2006 4:47 pm ] |
most of the quickshifts are built in the uk, the uk rod change box has a thinner casing so when people try to fit the quick shift to an aussie car they cannot select gears at times, although this might not be your problem, it may help to grind a bit of the inside of the quick shift bell out..??.. |
Author: | DarkenMini [ Sun Jan 22, 2006 12:13 am ] |
Is a quick shift even worth The money on a old gear box? I think it would be after A recon on a tyred Box but Not a Old gear Box? How Much travel does It Lose After installation. Is It Worth the Moneys? |
Author: | Monster Mini [ Sun Jan 22, 2006 8:49 am ] |
I installed one the other week ....we had problem with not finding first...we didnt have enough Play..........all fixed now..what we did is put a washer on the selector rod under the car leading to the gear changer infont of the box and all works good..... Hope this helps .... Cheers monster Mini ![]() ![]() ![]() |
Author: | GT1360 [ Sun Jan 22, 2006 8:54 am ] |
I think the quality of the quick shifts varys LOTS between brands also... |
Author: | Matt68 [ Mon Jan 23, 2006 12:33 pm ] |
A bit off topic but i recently installed the KAD remote quickshift and it is EXCELLENT. Had to fine tune how to space the bolt that acts as a guide, after that was done, all sweet. Cheers Matt |
Author: | GT1360 [ Mon Jan 23, 2006 3:14 pm ] |
Yep. I think the KAD ones are the best out of the lot.. only cause they made the first ones.. everyone else copyed there design ![]() |
Author: | dodge [ Thu Feb 16, 2006 7:32 pm ] |
my last one i fitted i had to chop 3 mm out of 1st 2nd selector rod , as it didnt stay in second , good as gold now , worth the 45 min conversion. |
