Shortening HT leads? https://ausmini.com/forums/viewtopic.php?f=5&t=15263 |
Author: | Hagar [ Fri Jan 20, 2006 1:06 pm ] |
Post subject: | Shortening HT leads? |
Has anyone mucked around with cutting and shortening HT heads? I want to have right angle plugs at each end, and have a few sets of spare leads, so I thought I might have a go. The way that they are stock (ie fibre core bared, folded over insulation and clamped by the steel plug) seems easy enough to replicate. Is there a reason why I shouldn't cut them? Radio interference?, risk of shorting? |
Author: | awdmoke [ Fri Jan 20, 2006 3:03 pm ] |
No problems doing it. You can even still buy leads in "kit" form where you cut them to length & put the distributor end contact on. (I've even used paperclips - they fit nicely) edit <distributor, not coil> fixed |
Author: | Hagar [ Fri Jan 20, 2006 3:21 pm ] |
Cool ...to the pliers! |
Author: | nathanSMC [ Fri Jan 20, 2006 3:43 pm ] |
excellent, that'll sure tidy up the engine bay |
