clubby into a roundy https://ausmini.com/forums/viewtopic.php?f=5&t=15222 |
Page 1 of 2 |
Author: | floss [ Thu Jan 19, 2006 6:15 pm ] |
Post subject: | clubby into a roundy |
hi all, reading the article about con's mini in fast fours http://www.ausmini.com/forums/viewtopic ... ht=#199498 He said that he got a clubby and made it into a roundie? is this something done commonly? Have any of you guys done this to a clubby? |
Author: | Marvin [ Thu Jan 19, 2006 6:59 pm ] |
there was already a little discussion about it here http://www.ausmini.com/forums/viewtopic.php?t=2157&highlight=fit+roundnose+clubby+front |
Author: | bnicho [ Thu Jan 19, 2006 8:56 pm ] |
I might be opening a can of worms here. But there are quite a few imported Rover Mini shells out there registered with the identity of a dead Clubman. I'm not saying the car Con built is using a Rover shell. But I know it is very hard to make an Aussie Clubman shell look exactly like a Rover one.... ![]() |
Author: | Mokesta [ Thu Jan 19, 2006 9:16 pm ] |
Lets drop this topic OK. Con's car is bloody great. Looks briliant, has a work of art subframe and I have followed it over Mt Glorious where it went like stink. It's just tops. Let's not get too picky about how it came to look the way it does. M |
Author: | clubmn [ Thu Jan 19, 2006 9:45 pm ] |
Post subject: | mini |
Yep i did it. I called it my roundman, I should have a pic or 2. i have seen it done twice before and they came up mint. My job was rat. |
Author: | floss [ Fri Jan 20, 2006 7:00 am ] |
i think his car look s great. He said in the article that that he got a clubman and then purchased all new roundie panels for the front. |
Author: | Caponix [ Fri Jan 20, 2006 11:07 am ] |
floss wrote: i think his car look s great.
He said in the article that that he got a clubman and then purchased all new roundie panels for the front. um why??? if you want a roundie front.....buy a roundy! |
Author: | Besser [ Sat Jan 21, 2006 8:39 am ] |
Post subject: | me too |
I'm looking at doing this and called minisport. For $450 I could have a complete rover front shell cut. Not bad I say! Love the name ROUNDMAN i think I'll adopt it |
Author: | floss [ Sat Jan 21, 2006 9:41 am ] |
this is probably a dumb question but would you get more room in a clubby shelled roundnose? David |
Author: | Marvin [ Sat Jan 21, 2006 9:44 am ] |
Yep Edit: ![]() ![]() |
Author: | ausminis4u [ Sat Jan 21, 2006 2:12 pm ] |
floss wrote: this is probably a dumb question but would you get more room in a clubby shelled roundnose? no u wont. all the extra room (90mm or so ) is from the clubman front pannels, everything such as firewall , subframe and crossmember are identical to round nose , so the answer is no .
David also the best conversion i have seen was ozmotorsports brg mini ( number plate NPU-55Y) dont know if he or the car is still around |
Author: | drmini in aust [ Sat Jan 21, 2006 3:49 pm ] |
ausminis4u wrote: floss wrote: this is probably a dumb question but would you get more room in a clubby shelled roundnose? no u wont. all the extra room (90mm or so ) is from the clubman front pannels, everything such as firewall , subframe and crossmember are identical to round nose , so the answer is no . David also the best conversion i have seen was ozmotorsports brg mini ( number plate NPU-55Y) dont know if he or the car is still around Oz and the numberplate are still on here, but that `PUSSY' car went north to Cane Toad Country... ![]() The numberplate is now on Baracade's old `Pretend GT'... ![]() |
Author: | marcsvenson [ Sat Jan 21, 2006 8:29 pm ] |
i would just save a little and get a mini K shell |
Author: | thomen [ Tue Jan 24, 2006 10:35 pm ] |
what would the cost of doing this sorta thing be?? im a total noob to welding and panel work but if i took a front cut shell to a panel beater and said take the clubby front of this car and replace it with the roundie how much would that set one back? any places people could recommend or are they all DIYers? ![]() |
Author: | thomen [ Tue Jan 24, 2006 10:53 pm ] |
brickworx are selling these!!! http://cgi.ebay.com.au/Mini-Rover-Bare- ... temZ460693 how much would it cost to fit one of these + remove old clubby front? if i were going to a shop!? |
