gearbox can handle 1380? https://ausmini.com/forums/viewtopic.php?f=5&t=15084 |
Author: | mickmini [ Mon Jan 16, 2006 7:08 pm ] |
Post subject: | gearbox can handle 1380? |
So i gets the spare remote change gearbox cleaned enough to look at the casting number. i got it out of a K and there is an 1100 sitting on top of it, but guess what? its a 3 synchro 22G382. ![]() so anyway, it should be good enough with a rebuild and "competition" diff pins to handle a 1380 with RE13 cam right? that seems to be the consensus here for every other gearbox type that the search came up with. apart from the advantage of synchro on first and possibly ratios of a K box, is there any reason not to use te 22G382? advice appreciated michael |
Author: | drmini in aust [ Mon Jan 16, 2006 10:10 pm ] |
Post subject: | Re: gearbox can handle 1380? |
mickmini wrote: So i gets the spare remote change gearbox cleaned enough to look at the casting number. i got it out of a K and there is an 1100 sitting on top of it, but guess what? its a 3 synchro 22G382.
![]() so anyway, it should be good enough with a rebuild and "competition" diff pins to handle a 1380 with RE13 cam right? that seems to be the consensus here for every other gearbox type that the search came up with. apart from the advantage of synchro on first and possibly ratios of a K box, is there any reason not to use te 22G382? advice appreciated michael Well the weakest thing in it is 1st gear outer ring, I broke one in 1/2 once first time I did a burnout. If you drive in a sane fashion it'll be OK, for a while at least. Does it have S gears in it? post the p/no of cluster gear (stamped in middle). ![]() Mini Deluxe ratios are pretty wide by current standards. Keep yer eyes open for a K or Mk2 S box, they are stronger. |
Author: | mickmini [ Tue Jan 17, 2006 7:18 am ] |
[quote="drmini in aust"] post the p/no of cluster gear (stamped in middle). ![]() [quote] gotta pull it all apart first ![]() |
Author: | GT1360 [ Tue Jan 17, 2006 7:31 am ] |
mickmini wrote: drmini in aust wrote: post the p/no of cluster gear (stamped in middle). ![]() Quote: gotta pull it all apart first ![]() Get to work then ![]() ![]() |
Author: | mickmini [ Tue Jan 17, 2006 9:32 am ] |
GT1360 wrote: mickmini wrote: drmini in aust wrote: post the p/no of cluster gear (stamped in middle). ![]() Quote: gotta pull it all apart first ![]() Get to work then ![]() ![]() i'm supposed to be writing a manual for the navy at the moment ![]() ![]() but yep, no holding back, gotta make the time and scare the wife with the parts prices ![]() ![]() |
Author: | drmini in aust [ Tue Jan 17, 2006 9:37 pm ] |
if motor is off box you can read the number on cluster in situ. Mk 1 S one is 22G1100 ![]() |
