How do I covert to unleaded...???? https://ausmini.com/forums/viewtopic.php?f=5&t=15069 |
Page 1 of 2 |
Author: | Monster Mini [ Mon Jan 16, 2006 3:35 pm ] |
Post subject: | How do I covert to unleaded...???? |
Hi does anyone know what needs to be done to covert from Super to Unleaded...any help would be great... Thanks Monster Mini ![]() ![]() ![]() |
Author: | fuzzy-hair-man [ Mon Jan 16, 2006 3:39 pm ] |
You need to take the head off take it to a engine reconditioners and get them to fit hardened valve seats and possibly new exhaust valves. ![]() Probably only needs hardened valve seats on the exhaust valves. ![]() Oh and was there something about different valve guides ![]() |
Author: | Monster Mini [ Mon Jan 16, 2006 3:50 pm ] |
Does anyone know the cost of this ...... Thanks Monster Mini |
Author: | h0nk [ Mon Jan 16, 2006 3:57 pm ] |
Can't remember the exact cost.. around $200 I think? But people reckon it's cheaper to keep using super with flash lube... I rather having the unleaded head.. it's much easier, you don't have to worry about additives |
Author: | Maxi23 [ Mon Jan 16, 2006 4:48 pm ] |
Yeah, im pretty sure its about the $200 mark. Had mine done 8 months ago when engine was rebuilt. |
Author: | speedy [ Mon Jan 16, 2006 4:50 pm ] |
Here some interesting reading for you on this very subject. ![]() http://www.ausmini.com/forums/viewtopic.php?t=14225 http://www.ausmini.com/forums/viewtopic.php?t=13847 |
Author: | JAM_IT [ Mon Jan 16, 2006 6:07 pm ] |
You supply the head.... $35 per seat FITTED + they will want to do a "service" on the head too.....wet blast, machine faces, lap valves and assemble = $120 |
Author: | Tinkz [ Tue Jan 17, 2006 7:52 pm ] |
Yeah we got quoted 400 for the whole job. Thats shaved, and all relevant parts added to the head to run unleaded. |
Author: | Lillee [ Tue Jan 17, 2006 8:53 pm ] |
Just use flashlube Marlene. Works out to be about 2-3c per tank. Why do you want to convert? If you are going to do that, then might as well get the head reconditioned. In fact whack on a 1098 12G202 head instead for more oomph. (I have a spare one and so will many people...) There is another option, an inline fuel catalyst for around $200. |
Author: | Boostedmini [ Wed Jan 18, 2006 11:55 am ] |
next time you pull up to the pump instead of lifting the "super" you lift up the 98 ultimate/optimax etc etc |
Author: | slide [ Wed Jan 18, 2006 1:32 pm ] |
It will limit the size of your exhaust valves if you convert to unleaded. If you want to get maximum performance out of your head then stick with super unleaded plus a dose of flashlube and fit the big valves (36 x 31 mm). |
Author: | MacktheMoke [ Tue Jan 24, 2006 5:32 pm ] |
I've got a fuelstar in my moke and I haven't had a problem- simple to fit- put it in between the fuel line from the pump to the carby. Took 5 mins. ![]() http://www.aapsa.com.au/fuelstar.htm |
Author: | drmini in aust [ Tue Jan 24, 2006 6:02 pm ] |
MacktheMoke wrote: I've got a fuelstar in my moke and I haven't had a problem- simple to fit- put it in between the fuel line from the pump to the carby. Took 5 mins.
![]() http://www.aapsa.com.au/fuelstar.htm Mack, I'd pull the head off it for a look after 12 months.. There was a test done in UK a while back, where they ran a stock 998 Mini flat out round a track for 500 miles, after doing a valve service and fitting a catalyst (can't remember what the brand was). The deal was if any valve recession was evident after that, the owner would get a new head. Guess who got a new head then... ![]() ![]() ![]() <edit> Not saying NONE of these things work, but be careful there are shonks out there! What do I do? Barney has Rover unleaded seats, and Ha-Ha runs Flashlube because his ex valves are too big for inserts... ![]() Having seen what happens to a 1098 head in 6 months with NO additive, I know Flashlube works. I get less valve and seat wear now than I used to get with leaded fuel. |
Author: | MacktheMoke [ Thu Feb 02, 2006 6:28 pm ] |
Fair enough! I'll definitely do that then. ![]() Might end up fast-tracking the 1100 head I want for Mack if It all goes bad. Cheers for the heads up! ![]() |
Author: | mini_tom [ Sat Feb 04, 2006 12:05 am ] |
Post subject: | Petrol |
Is super the same as leaded fuel? is it worth the effort to change a mini onto unleaded? |
