https://ausmini.com/forums/
Supercharge or turbo a+ mini
https://ausmini.com/forums/viewtopic.php?f=5&t=14839
Page 1 of 2
Author:  duckpowder [ Wed Jan 11, 2006 1:15 pm ]
Post subject:  Supercharge or turbo a+ mini
Hi
i have a 1310 A+ mini motor and want to know what would give me more hp.
so what im thinking is
Turbo i would use a mg metro turbo
or
toyota SC12 supercharger
so what would be better??
thankyou
Author:  Spaceboy [ Thu Jan 12, 2006 7:19 pm ]
turbo
Author:  marcsvenson [ Sun Jan 15, 2006 4:45 pm ]
depends what you want
turbo = more bhp possible, more effecient, more bits of trick peices available
but more money more heat more effort
supercharger = eaasy install, good low torque cheaper
Author:  erin [ Fri Jan 27, 2006 2:57 pm ]
Is it going to be a daily driver or weekend fun car?
Author:  gafmo [ Fri Jan 27, 2006 8:10 pm ]
S/C = will be a contant power
Turbo = normal power then a kick
Author:  Fat Boy Dave [ Sat Jan 28, 2006 4:51 pm ]
Theres also the noise.
Supercharger, constant whine
Turbo, whine when spooling up, and other noises if you have an external wastegate :P
I guess my wife's more like a supercharger... :?
Author:  cush [ Sat Jan 28, 2006 10:29 pm ]
that's why married men tend to install superchargers.... the don't notice the constant whine anymore.. ;)
Author:  Fat Boy Dave [ Sun Jan 29, 2006 11:41 am ]
Seriously though, I am considering installing a supercharger but one of the things that I was wondering about was the noise.
Could someone who has one, or has been in a Mini with one please let me know how much more noise there is. As my car is a daily driver, and constant whine would s#$t me after a while. That and the sleeper value would be great!
Author:  erin [ Sun Jan 29, 2006 12:23 pm ]
There is a certain kind of supercharger that can be run at will - I don't remember what it was, but the guy that does my suspension had one on his commie for a bit of fun.
Author:  duckpowder [ Sun Jan 29, 2006 8:43 pm ]
Hey HEy i think i will go for a turbo mini but what do i need and where do i get everything
anyhelp would be great
Author:  Jules [ Mon Jan 30, 2006 12:19 am ]
Toyota SC12 has an electromagnetic clutch in the pulley, so the drive can be switched on and off at will (like an air con compressor). When it's on it doesn't make much noise - more of a hum than a whine - and when it's off it makes no noise at all.
Author:  TheMiniMan [ Thu Feb 02, 2006 8:24 pm ]
Now this is the go,,,Turbo Injected twin Cam 16V Mini engine
Yeah!!!!!!!!
Author:  h0nk [ Thu Feb 02, 2006 8:30 pm ]
Is that a FMI or is that the radiator?
Author:  Molina [ Fri Feb 03, 2006 10:02 pm ]
What happens to the mixtures when you switch it off? Can you run it without the supercharger switched on with normal drivability?
Author:  Jules [ Sat Feb 04, 2006 10:59 am ]
The Toyota installation has an air valve which bypasses the supercharger - it's open when the supercharger drive is off, and driveability is normal.
The Toyota ECU knows whether the supercharger is on or off, so injects the appropriate amount of fuel. A suck through carby would sense the change in air flow so mixtures should be fine if it's properly calibrated.
