https://ausmini.com/forums/
replace front apron
https://ausmini.com/forums/viewtopic.php?f=5&t=14790
Author:  thomen [ Tue Jan 10, 2006 9:25 am ]
Post subject:  replace front apron
Hi all just wondering where in australia i could source a panel like this and any ideas on the cost of fitting etc?
http://www.minimania.com/web/Item/MS4E/ ... Detail.cfm
thanks!
- tom
Author:  GT1360 [ Tue Jan 10, 2006 10:13 am ]
Minisport SA should have them in stock.. also maybe Karcraft
Ring for Price. I cant remember of the top of my head today :oops:
as for fitting.. any pannel place can do it.. or do it yourself. 8)
Author:  benjamin [ Tue Jan 10, 2006 10:20 am ]
karcraft or minisport sa would have them
edit> well what cody said
Author:  thomen [ Tue Jan 10, 2006 11:57 am ]
thanks cody! thanks ben!
Author:  drmini in aust [ Tue Jan 10, 2006 9:59 pm ]
Heritage MG has them too. :wink:
Author:  manofaus [ Wed Jan 11, 2006 7:10 pm ]
I saw one on fleabay for 300 bucks I think
I put one on my mini three years ago cost 260 back then
I cut off most of the old one, but ground out the last of it from the seams. I then stitch welded it to the old body panels. Had 4 pairs of vice grips to to the alignment job.
I used sikaflex on the joints after welding them in places so that the dirt and crap didn't get behind the panel. I also ran a bead along the bottom of the thing, where they have spot welded the stone tray(?) to the front main section. took about a day.
I imagine a beater would also do it in a day... I don't know what they charge.
Author:  Besser [ Thu Jan 12, 2006 12:44 pm ]
Post subject:  ++
I might add that when I replace panels I unstitch the old one by drilling out the spots and over heating the braze even use a cold chissel. Then clean up the mating surfaces back to bare metal. Spray them with weld through primer that is loaded with zinc, then Mig through the drill out holes. Seems to have worked so far and it doesnt seem to trap any moisture like seam sealer. Any rust I clean back and give a squirt of weld through primer.
My panel beater friend tells me to use seam sealer though.
Author:  IwannaMini [ Fri Jan 13, 2006 7:26 am ]
Dont you need a car first before changing panels..
:lol: :wink:
