How to mount the Pulsar Dizzy????? https://ausmini.com/forums/viewtopic.php?f=5&t=14668 |
Author: | Monster Mini [ Fri Jan 06, 2006 9:34 pm ] |
Post subject: | How to mount the Pulsar Dizzy????? |
Hi Guys, I just got hold of the new Pulsar N12 dizzy, and have done all of the mods with regards the shaft and so on. The only question that I have is with regards the mounting of the unit to the engine. Here is a picture of the clamp that came of the old distributor. ![]() Here is a picture of the dizzy mounting braket on the N12 ![]() The question is; do I cut off the existing mounting bracket? Then will bracket in the first picture fit around the casing or do I have to file off the fins on the casing as shown here?..... ![]() If someone can point me in the right direction it would be much appreciated. ![]() |
Author: | drmini in aust [ Fri Jan 06, 2006 9:50 pm ] |
OK, you get a hacksaw and cut that lug off. Then file or linish that bit down carefully, until it's the same diameter as the round part- which just happens to be the right size for the clamp. Make sure the clamp is round inside, people overtighten them and bend the **** out of them. But yours looks OK. ![]() |
