https://ausmini.com/forums/
Right Hand Fuel Tank
https://ausmini.com/forums/viewtopic.php?f=5&t=14645
Author:  lefty [ Fri Jan 06, 2006 11:46 am ]
Post subject:  Right Hand Fuel Tank
Hi: Does anyone have a diagram or photo showing how / where the support bracket under the RH fuel tank goes?? Not the strap that goes over the top from back of seat to floor, the metal support thing that sits somehow under the tank. Thanks
Author:  minstar [ Fri Jan 06, 2006 2:58 pm ]
Lefty, on my clubby it was a thick piece of felt (1/2 inch) so I replicated that when I put the right one in, but used a thick piece of rubber.
Author:  Besser [ Fri Jan 06, 2006 10:05 pm ]
Post subject:  copy and paste
Find a donor car and cold chisel the LHS tank support off the boot floor then transfer it to your car in the same position except on the RHS. Tack it in trial fit tank then secure when happy.
Worked on my car
Author:  1380 yellow devil [ Sat Jan 07, 2006 3:29 pm ]
When I fitted mine I never used one and it fits fine with out any movement.\
I had gotten the correct Cooper S Bracket that goes on the Back of the boot wall.
I have not go any photos to show you tho.
Author:  mad-mk1 [ Sun Jan 08, 2006 8:26 am ]
i bought the complete fitting kit from minisport. well ebay, its got prettymuch everything you need, pipes,lines brackets voltes etc etc
