https://ausmini.com/forums/
Late Type Brake Servo Master Cylinder
https://ausmini.com/forums/viewtopic.php?f=5&t=14279
Author:  redGhia [ Sat Dec 24, 2005 8:19 pm ]
Post subject:  Late Type Brake Servo Master Cylinder
Hey guys,
Just had my Brake servo delivered (non remote) Due to clearence isses i need to find a diffrent master cylinder setup with the brakelines exiting on the right hand side of the master cylinder instead of the left,
Ps, It is a Disc/ Drum setup
If anyone knows of anything could you let me know pls,
Regards,
Ash
Author:  13secmini [ Sun Dec 25, 2005 8:03 am ]
hi ash,
I also had clearance issues with my brake master. Im using a twin line late model one and had to weld 2 new lugs on the base of it to spin it around 90 degrees to clear the inlet manifold.
Why are you having clearance issues? what motor you putting in?
Author:  redGhia [ Sun Dec 25, 2005 8:33 am ]
B16A Vtec - It is a VERY tight fit between the dizzy and master cylinder, have looked at going to a Coil on plug setup but i think it will be cheaper and easier to find another master cylinder
Author:  13secmini [ Sun Dec 25, 2005 9:21 am ]
Have you got a picture of it? you sure its not the clutch master in the way? i thought the dissy on the b16a was closer to the clutch master?
Here is a pic of a honda mini, he is using a mazda master with a relocated reservior.
Author:  feralsprint [ Sun Dec 25, 2005 9:48 am ]
Is that charlie's super min
