Weber Manifold https://ausmini.com/forums/viewtopic.php?f=5&t=1401 |
Page 1 of 3 |
Author: | 1310/71 [ Tue Aug 03, 2004 8:10 pm ] |
Post subject: | Weber Manifold |
OK guys, What's the best inlet manifold to use for a 40DCOE weber in a clubman (1310) road car where I don't want to create an airbox or make any mods to the bulkhead? where from?/How much? I've currently got a swan neck one with Lynx filter which I've been told isn't the best but fits in nicely with no mods (the inlet manifld I mean). I need to do something about the extractors, so now is a good time to change inlets if need be. Similar question - what exhaust extractors are best? KB |
Author: | drmini in aust [ Tue Aug 03, 2004 8:27 pm ] |
Redline #3005 is about the best about at the moment, if you don't want to cut holes. Mini Classic has some new for around $120. If using a 45 carb, they could do with some enlargement. Stock they are not bad for a 40. Lynx Ramflo 440S filter (offset up) fits in there, just.. not much room for anything else. Mine has a Finer Filter pad in it (hard to get now). Here's a pic of the Redline with a 40DHLA on it- Extractors- for a 1310 I like Maniflow medium bore LCB, they are better than most. |
Author: | 1310/71 [ Tue Aug 03, 2004 8:40 pm ] |
Thanks Doc, coincidently I rang hardiman's today and the 3005 is $160 odd incl GST, the linkage kit about $100. I knew they did one, didn't know if it fitted without mods. Cool. Where's the best place to get the Maniflows from? Hardimans said they ordered in "hurricane" extractors (3:2:1) as required, but I've heard of Maniflows before in the UK mags. KB |
Author: | drmini in aust [ Tue Aug 03, 2004 8:45 pm ] |
Note the 2 home-made `stubstacks' on the carb. Yes they do clean up the throttle response at low revs. They fit inside the Ramflo filter. ![]() |
Author: | Christoph [ Tue Aug 03, 2004 8:45 pm ] |
Kev, Did you machine the 'eliptical flares' yourself? Dont they flow better than properly designed ram pipes? |
Author: | drmini in aust [ Tue Aug 03, 2004 8:48 pm ] |
I copied them from Vizard's book. Bore is 40 or 45mm, radius is 4.0mm, back angle cut is 30* from filter housing. It does run sweeter. No room for traditional ram pipes, but Vizard says they are as good! |
Author: | drmini in aust [ Tue Aug 03, 2004 8:51 pm ] |
1310/71 wrote: Thanks Doc,
coincidently I rang hardiman's today and the 3005 is $160 odd incl GST, the linkage kit about $100. I knew they did one, didn't know if it fitted without mods. Cool. Where's the best place to get the Maniflows from? Hardimans said they ordered in "hurricane" extractors (3:2:1) as required, but I've heard of Maniflows before in the UK mags. KB Karcraft do the Maniflow now. $221 in my old catalog. KC102. |
Author: | drmini in aust [ Tue Aug 03, 2004 9:25 pm ] |
Here's an unfinished project I'll try one day. Yes it fits in a roundnose with 1275- there's a whole 10mm clearance... ![]() <edit> The plastic bottle with red lid is not part of the kit....! |
Author: | thommo09 [ Tue Aug 03, 2004 9:28 pm ] |
doc....how many spare carbs do u have just sitting around?!?! wanna sell one? ![]() |
Author: | drmini in aust [ Tue Aug 03, 2004 9:33 pm ] |
Er... this carb is the same one in previous pic. It's going on the 1132 Clubbie as soon as registered. Very soon! ![]() |
Author: | gafmo [ Tue Aug 03, 2004 9:35 pm ] |
HHmmmmmm Nice Air Box. Sorry Wrong Forum...Again. ![]() You Whana to sell it..the Webber Set up that is ![]() |
Author: | drmini in aust [ Tue Aug 03, 2004 9:42 pm ] |
This 40 Dellorto & manifold etc is going into the Clubbie, so not for sale- sorry! ![]() Got no spare carbs at the moment. |
Author: | gafmo [ Tue Aug 03, 2004 10:12 pm ] |
If you dont ask you dont recieve ![]() |
Author: | supercharged 850 [ Wed Aug 04, 2004 2:54 am ] |
drmini in aust wrote: I copied them from Vizard's book.
Bore is 40 or 45mm, radius is 4.0mm, back angle cut is 30* from filter housing. It does run sweeter. No room for traditional ram pipes, but Vizard says they are as good! ....now, WHERE did i put my lathe..... OH... thats right... i dont have one. crap. ![]() |
Author: | drmini in aust [ Wed Aug 04, 2004 7:12 am ] |
Best workshop tool I ever bought (S/H). Everyone should have one. ![]() |
Page 1 of 3 | All times are UTC + 10 hours |
