It is currently Tue Jul 01, 2025 9:43 am
PostPosted: Mon Dec 12, 2005 8:17 pm
I found some morris 1100 disc brakes and don't know if they will fit my 71 clubman. this is my first ever mini and i dont know much about themjavascript:emoticon(':D')
Very Happy
PostPosted: Mon Dec 12, 2005 8:54 pm
Short answer = NO. :cry:
But somebody here was attempting this feat.
PostPosted: Mon Dec 12, 2005 9:25 pm
A bloke in adelaide has done it.
He had the rotors turned down to whatever they were to fit under his wheels ( i think)
used morris 1100 calipers.
And drum brake uprights.
Made up mounting plates - no dodgier than your Honda crap let me tell you! :lol:
And there it was.
Morrie 1100 brakes on a mini. :D
PostPosted: Mon Dec 12, 2005 9:29 pm
And there it was.
Pfffft... Hondas will outstop them easy- they are 9.1", and are ventilated too if you grab Accord ones!
BTW the mounting plates are 8mm thick... plenty.
Sorry I don't do them any more though.... :lol:
PostPosted: Mon Dec 12, 2005 9:57 pm
And why dont you :)
PostPosted: Mon Dec 12, 2005 10:10 pm
- Cono from mini craft here in perth makes a kit that allows the brakes to fit..
- Probably not worth it tho.
1978 Leyland clubman S.
PostPosted: Tue Dec 13, 2005 5:54 am
willy wrote:
And why dont you :)
Not engineered, and neither are M1100s on a Mini if you succeed in fitting them.
PostPosted: Thu Dec 15, 2005 9:36 am
lots of problems surrounding the fittment of morris 1100 disc assys,,,
the upright/swivel hubs won`t work for starters, the ball joints are way too far apart & will leave absolutely no room for suspension travel at all, so different swivel hubs are needed or lift the upper inner control arm mounting point & shorten the strut/Hi-lo assy & raise the tower bump stop part of the subframe. (MAJOR DRAMA)
The disc & caliper are too big to fit under 10" wheels & would need turning down & as the good Doc said, there`s many other brake conversions out there that will work far better
about the only good thing is that you can actually use the disc rotor with the moke/1275LS brakes (if you had to) in that they`re only a tad smaller in diameterthan the moke/1275LS rotor, so they work, but only just & you`ll need to chip away all the over hanging (unused) brake pad material from time to time
just simply not worth the stuff around
YUK!!!!!!!!!!!!!!!!!!!!!!
Users browsing this forum: No registered users and 26 guests
