It is currently Sat Jul 05, 2025 11:29 am
 Post subject: BEST OIL TO USE
PostPosted: Fri Nov 25, 2005 3:53 pm
:D I was wanting to know the best oil to use in a modded 1330 motor
is fully synthetic OK , some info would be good. Thanks
850 MONSTER
PostPosted: Fri Nov 25, 2005 4:43 pm
I'm pretty sure you don't want to be using synthetic oil. Cause the gearbox uses the same oil you need a thicker one. You want non synthetic, 20W-50... Do a quick search, theres a few topics on this.
PostPosted: Fri Nov 25, 2005 4:50 pm
Synthetics are a No-No ;)
It's up to many people's preference, but IMO the best oil is Castrol's Formula R 20w50 NON SYNTHETIC..you can tell it's not cause it'll be alot cheaper :lol:
As Alex said, do a search, there have been many many toppics discussing it.
PostPosted: Sat Nov 26, 2005 4:17 pm
Castrol Formula R is what I use. 8)
PostPosted: Sat Nov 26, 2005 6:15 pm
penrite HPR30 20w60 best in my opinion
PostPosted: Sat Nov 26, 2005 9:16 pm
whinja ninja
whinja ninja
Anything with an SF/SG rating is the best. They're also the cheapest. Dont use any higher gradings, such as SL, SK for example. These types of oils are bad for your gearbox, and a minis engine and gearbox share the same oil.
O, and before it gets said, Sk/Sl oils ARE NOT BETTER OILS. They are different oils, designed for new cars.
The rating can be found on the bottle. Sometimes on the front, but usually on teh back in tiny writing.
I don't know my name anymore.
PostPosted: Sat Nov 26, 2005 11:05 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
castrol type r here
makka
PostPosted: Sun Nov 27, 2005 5:46 am
I run Valvoline `SF' 20W/50 in Barney, and change it every 1500 miles (filter at 3K). Holds pressure well hot, even after a freeway run.
With Ha-ha I did the same, but following my recent main bearing problem at Wakefield Pk (engine build related, probably no fault of the oil) I'm going back to Castrol Formula R 25W/50 for track work. 8)
PostPosted: Mon Nov 28, 2005 11:56 pm
i run BI-LO $4.99 oil :wink:
nah, i used to run castrol type r as well, switched to Fuchs Titan GT 2050. Dont know why i switched, just felt like a change i spose.
PostPosted: Fri Dec 02, 2005 6:24 pm
Penrite, for 20 years now.
I allways use a non friction modified engine oil in the road Minis.
PostPosted: Fri Dec 02, 2005 6:52 pm
valvoline was my choice XL or XLD for a road car and racing 50 for the track, never had a problem with this brand
PostPosted: Sat Dec 03, 2005 12:50 am
super stuff that :roll:
PostPosted: Sat Dec 03, 2005 1:11 am
yeah i usually use valvoline 20/50, minis can and should run on "primitive" oil as that was what they were designed to run on.. its easier on the wallet too.. unless you run that super good stuffs like penrite like i do in my race motor.
PostPosted: Sat Dec 03, 2005 1:24 am
i heard that kmart oil was made by shell anyway, so other "no name brands" are most definately made by the big oil companies.
PostPosted: Sat Dec 03, 2005 9:52 am
lol i heard that too, but um, no ive never used bi-lo oil in anything......period.
