1310 on ebay https://ausmini.com/forums/viewtopic.php?f=5&t=13546 |
Author: | harvey69 [ Mon Nov 28, 2005 8:28 pm ] |
Post subject: | 1310 on ebay |
http://cars.search.ebay.com.au/mini_Car-Parts_W0QQcatrefZC12QQfromZR8QQfrtsZ300QQfsooZ1QQfsopZ1QQsacatZ72364 wat u rekon waste of money??? |
Author: | aussie [ Mon Nov 28, 2005 8:30 pm ] |
heres the link u want... http://cgi.ebay.com.au/Mini-1310-Motor_ ... dZViewItem |
Author: | willy [ Mon Nov 28, 2005 8:35 pm ] |
Its a 3 cylinder version! ![]() Not bad price, if everything is correct. I guess it's only a head gasket - being a 1310 they arent the best for head gaskets. |
Author: | Lillee [ Mon Nov 28, 2005 8:41 pm ] |
Including G/B that's ok... So long as it is running on 3and not let a big end bolt go or dropped a valve or something like that... |
Author: | mickmini [ Mon Nov 28, 2005 9:24 pm ] |
possible burnt valve or done a ring if its only 20psi down on one cylinder. if it dropped a bolt, just spinning to do the compression test would probably make nasty sounds not a bad price for a rebuilder |
Author: | drmini in aust [ Tue Nov 29, 2005 5:46 am ] |
If only 20psi down on one cyl it's probably just a valve. Fix that first and it could be OK. I agree, price is good.... even better if it's a good runner. ![]() |
Author: | Lillee [ Tue Nov 29, 2005 12:37 pm ] |
Even even better if that was a remote box under there ![]() |
Author: | Mike_Byron [ Tue Nov 29, 2005 3:46 pm ] |
I emailed the guy - the motor is a 12H902UH and the gearbox is SM 2261832 |
Author: | drmini in aust [ Tue Nov 29, 2005 7:46 pm ] |
would be 22G1832 = rod change box, small idler (ie std Oz one). |
Author: | Lillee [ Wed Nov 30, 2005 8:51 am ] |
Still worth it for a complete engine with all the gear (dissy, alternator etc) |
