It is currently Wed Jul 02, 2025 7:07 am
 Post subject: hydraulic lifters
PostPosted: Wed Nov 23, 2005 7:21 pm
Is it possible to get hydro lifters for a mini engine? Do you need to get a hyrdo camshaft aswell or can you stick to the solid state cam?
PostPosted: Wed Nov 23, 2005 7:45 pm
No way to run hydraulic lifters in a Mini, the oil gallery for pressure feed ain't there.
Ummm WHY would you? :shock:
PostPosted: Wed Nov 23, 2005 8:05 pm
So that you could run anti-pump up lifters of course. 8)
PostPosted: Thu Nov 24, 2005 6:49 am
quieter, low maintenance, my engine isn't very high performance - looks like i'll be keeping the solids anyway
PostPosted: Thu Nov 24, 2005 7:07 pm
Your engine is antique, designed ~ 1952- probably before hyd lifters were invented.
There was even a version of it in a (Mini) tractor. :shock:
Solids give more power anyhow, usually..... :wink:
PostPosted: Fri Nov 25, 2005 11:53 am
I'll stick to the solids.. but with the oil gallery, can't you just use hollow push rods?
Users browsing this forum: No registered users and 24 guests
