Cooper S Brakes conversion from drums https://ausmini.com/forums/viewtopic.php?f=5&t=13132 |
Author: | Lillee [ Mon Nov 14, 2005 7:55 am ] |
Post subject: | Cooper S Brakes conversion from drums |
Almost done! I wish I could say it was done... Story to date: Months ago I went against very good advice and purchased as second hand set of Cooper S discs and have been buying replacement parts since then ![]() Fast forward to last weekend, Dr Mini helped me rebuild the calipers with new kits, new pistons, new seals. Back brake cylinders changed to S ones, new brake lines at the back, hubs have new bearings, 4 new ball joints, brand new CVs, boots, etc. This weekend I dismantled everything, changed the left brake hose which was a piece of cake, but the right hand one was challenging to say the least! ![]() Anyway all in the past now, new lines are in, calipers bolted on. Then I found that the Karcraft disc pad split pins were WAY too big! These are the right pins but the tolerances were way off! ![]() ![]() Whole system bled, pedal feels good but I think there is still air in there as the system ran dry due to the awkwardness of the right hand hose ![]() Kev had to also "remodel" the calipers so that they would clear the LS contessas. Only 1-2mm off each bleed nipple lug. The left hand one was a perfect match however the right hand one still touched, but only just... So tonight I will angle grind away 1/2mm to get it clear off the wheel and then all that's left is wheel alignment. Then I will have a "sleeper" Mini K! no flares! yeah baby ![]() ![]() ![]() Some pics tonight. |
Author: | Lillee [ Mon Nov 14, 2005 8:46 pm ] |
Here are the pics as promised. I tell ya they fit snug under the arches without flares. Full sleep look style ![]() ![]() ![]() ![]() Sorry didn't take any better pics... |
Author: | drmini in aust [ Mon Nov 14, 2005 8:49 pm ] |
These calipers fit so close in there.. ![]() No room for stick-on weights, even in the middle! Inner ones need to be clip on and `ping' off style. ![]() |
Author: | Lillee [ Mon Nov 14, 2005 8:58 pm ] |
Woops, forgot to give FULL credit to the good Doctor for all his help! Your a legend Kev!!! ![]() |
Author: | 1310/71 [ Mon Nov 14, 2005 9:29 pm ] |
drmini in aust wrote: These calipers fit so close in there..
![]() No room for stick-on weights, even in the middle! Inner ones need to be clip on and `ping' off style. ![]() With the brand new calipers I bought, there was no way they were going to clear on LS contessa's. I thought of spacers and even then, I don't think so. Congrats Chong, almost done. You must be hanging out to drive Lillee again. KB |
Author: | gafmo [ Mon Nov 14, 2005 10:18 pm ] |
Congratulations Chong..and well done. the Time/time/time and effort has been well worth it did you replace the rubber boots on the ball joins by chance? Cheers |
Author: | WhoDat [ Mon Nov 14, 2005 10:41 pm ] |
Logic suggests that you have done better than you would have by just buying a new set of brakes You appear to not only have "now new" S brakes, but also hoses all round, Plus uprated back cylinders, Plus new lines, Plus new wheel bearings, Plus 4 new ball joints, Plus new CV's, Plus boots. Take off the price of all the things you have there [that you would not get with a new set of brakes alone], and I think you'll find youv'e done quite well. You have as new brakes plus all the rest. Nice feeling, knowing you have stoppers that work. Cheers Dat |
Author: | drmini in aust [ Tue Nov 15, 2005 5:56 am ] |
All he wants now is a plastic extension for the`bean can MC' and he'll be a happy chappie. Anybody got one this side of UK? ![]() |
Author: | Lillee [ Tue Nov 15, 2005 8:03 am ] |
Yeah I am pretty happy with it all. Took her for a drive last night around the block and there is definately air in the back system. Other than a spongy feeling brake pedal she does stop much better. Stops straight which is more important! and stops over and over again which really what makes it worth the while! ![]() New everything Jimbo... Ball joint kits come with new rubber dust caps. I even selected out of a collection of grease nipples the tightest, least worn nipples. About the only things second hand are the hubs themselves, the calipers, the drive flanges and discs. I will bleed them properly tonight and align the wheels and we are good to go! ![]() |
Author: | drmini in aust [ Tue Nov 15, 2005 7:14 pm ] |
68Delux wrote: Yeah I am pretty happy with it all. Took her for a drive last night around the block and there is definately air in the back system. Other than a spongy feeling brake pedal she does stop much better. Stops straight which is more important! and stops over and over again which really what makes it worth the while!
![]() Must be those 1970 vintage NOS `General' brand asbestos brake pads I gave you.. ![]() |
Author: | Lillee [ Tue Nov 15, 2005 8:21 pm ] |
Yeah *cough* *cough* they stop great *cough* ![]() Here is a surprise, the wheel alignment is still correct! ![]() ![]() ![]() Bleed the brakes back then front, lots of pedal now ![]() |
Author: | Stuwey [ Tue Nov 15, 2005 9:42 pm ] |
My mate has a pair of those plastic extentions for the 'bean can' MC... He didn't end up using them on his Nb car, so i'll give him a call and see if he wants to offload them for a small fee. ![]() |
Author: | drmini in aust [ Tue Nov 15, 2005 9:51 pm ] |
Look like this- ![]() |
Author: | Lillee [ Wed Nov 16, 2005 6:15 pm ] |
Sweet! that'll be great! no more spillage! ![]() |
Author: | Stuwey [ Wed Nov 16, 2005 10:38 pm ] |
Um yer, they look like that... But about 29 years older ![]() Will suit the vintage of the car better, anyways. I'll give haim a call for ya tomorrow ![]() |
